F22b Forged Pistons without over boring
I've searched ebay, amazon, and the rest of the internet marketplace for "94 honda accord f22b forged pistons" and the only compatible product that comes up is h22 87mm bore, which requires 1mm of iron liner to be shaved from the 85mm bore f22 block.
After looking through wiseco's full catalog I noticed 85mm bore pistons available for the b18c, so I looked at the other numbers:
85mm bore, 30.5562mm comp. height on stock f22b pistons
85mm bore, 30.0000mm comp. height on Wiseco K594M85AP b18c pistons
Am I overlooking something, or is this piston compatible with f22b so long as I keep stock specs for stroke length and rod length?? And wouldn’t this be ideal for lower compression, forced induction applications?
Race Engineering is the place to look! I have purchased a number of F22B parts from them without issue. If you want custom pistons they can order them as well.
Another thing to remember is that a lot of F22A SOHC internals are interchangeable with the F22B SOHC. Check out there F22 page; http://www.raceeng.com/c-335-f22-f22af22b.aspx
Another thing to remember is that a lot of F22A SOHC internals are interchangeable with the F22B SOHC. Check out there F22 page; Race Engineering, Inc - F22 (F22A/F22B)
hatchinprogress
Nov 14, 2005 08:36 PM
