car wont start
Old Jul 18, 2015 | 05:36 PM
Skids1's Avatar
Default car wont start
So i have a 97 itr. originally the problem i was having was the starter solenoid was going so i went out and got a brand new bosch starter and installed that and now the car wont start or turn over at all. ive also put in a new ignition switch and have checked everything else i can think of (power, grounds, fuses etc) i find it odd that the car was starting before and now just nothing and all ive done is change the starter and switch. any suggestions or possibilities for things i might be over looking or should check?
Old Jul 18, 2015 | 06:55 PM
thadon805's Avatar
10 Year Member
Default Re: car wont start
Sure it wasn't a bad battery ?
Old Jul 18, 2015 | 08:05 PM
Skids1's Avatar
i havent checked much with the battery yet simply because its only like a year old and has a disconnect switch on it so its been turned off until now pretty much, but i will do some more testing on that to make sure
Old Jul 19, 2015 | 07:15 PM
SiClone's Avatar
I had a trickle charger on my battery and it started fine after winter. Let it run for a good 29 mins. Turned off and it wouldn't start again even after I put the trickle in it again.
Connected a new red top I just ordered from eBay and it fired right up.
Went and got a brand new Oreilly battery just to help out the thieves that took her a couple weeks ago.
Old Jul 19, 2015 | 08:46 PM
2000FBPITR's Avatar
Have you tried running a hot wire to where the White/Black wire is that cranks over the starter to see if it turns?
Old Aug 1, 2015 | 09:09 PM
Skids1's Avatar
Sorry for the late reply. Yes I can Hotwire it from the prong on the solenoid to the ground cable/nut and the car will start
Jmx305
12
Dec 9, 2013 03:20 AM
lPat
Nov 3, 2007 08:19 AM
OPTION2ek V.2
Jul 7, 2005 05:56 PM
zxg
Jan 5, 2005 03:18 PM
badazzaccrd
May 29, 2004 10:05 PM
