96 del Sol S harness question help!!!
Old Jul 18, 2015 | 04:48 PM
Chewydelsol's Avatar
Default 96 del Sol S harness question help!!!
Ok so I'm swaping a z6 into my 96 del Sol S I was just wondering if I can a z6 harness to it since its a two piece harness? Or what other harness can I use? I did use the original harness but seem to be missing alot of air sensor my car idels and my tb whistle? Any info will help me at this point thanks.
Old Jul 18, 2015 | 05:32 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 96 del Sol S harness question help!!!
no, you cannot use an obd-1 harness in your obd-2 car. you'll need to piece the two harnesses together. you'll need the 2 wire iacv plug from your z6 harness, and to convert your current harness from 3 wire to 2 wire. 3 Wire to 2 Wire IACV Conversion for 96-98 Civic you'll need the two vtec solenoid wires from your z6 harness, and you'll need to run those into the ecu. .:FFS TechNet : OBD2a ECU Pin out Schematics :. if you're running an obd-2 ecu, you'll need to bypass the ckf sensor, because the z6 does not have one. .:FFS TechNet : CKF Bypass Trick :. finally, you'll need a jumper harness for the z6 distributor so that it plugs into the y7 harness, or to swap the y7 guts into the z6 dizzy. Civic EG :: View topic - DIY: Distributor Rebuild
Old Jul 18, 2015 | 05:44 PM
That's exactly what I did on my obd2 harness but it still idels?
Old Jul 18, 2015 | 05:53 PM
94EG8's Avatar
Seagull Management
Yes you can use the Z6 harness.
Old Jul 18, 2015 | 06:01 PM
OK I'm confuse can anyone confirm it haha it would really help me a lot
Old Jul 18, 2015 | 06:52 PM
94EG8's Avatar
Seagull Management
'96 - '97 Del Sols (unlike '96 - '00 Civics) use a 2 piece harness the same as '92 - '95 Civics and Del Sols. Using a Z6 harness makes everything easy, the harness is a direct plug in at the shock towers and you can keep the Z6 distributor (no OBD2 version exists), alternator, and ECU.
Old Jul 18, 2015 | 06:54 PM
Thank you I will try it!!!
Old Jul 18, 2015 | 07:03 PM
tony_2018's Avatar
Fish Twig
^^Ditto, because they still use the same 92-95 civic/94-01 integra design it should still function.
Old Jul 19, 2015 | 06:25 AM
Any idea what that last plug is?
Old Jul 19, 2015 | 06:36 AM
94EG8's Avatar
Seagull Management
Probably Knock, CKF, and some other OBD2 stuff.
Also, you'll need to do this:
Old Jul 19, 2015 | 07:11 AM
OK now what is the cause for my ecu fuse to keep blowning on me!? Sorry guys if I have to much questions
whyS0serious
May 25, 2013 08:13 PM
B16KENNY
14
Apr 29, 2013 08:06 AM
aalouie
May 30, 2012 05:58 PM
JDCB16Cx
Feb 26, 2007 12:15 PM
17
Jul 30, 2006 05:43 PM
