2001 Honda Accord V6 - Not cranking. Is this the starter?
Old Jul 18, 2015 | 04:34 PM
spooksmcgee's Avatar
Default fixedfixed
fixed
Old Jul 19, 2015 | 02:40 AM
Lost Again's Avatar
Default Re: 2001 Honda Accord V6 - Not cranking. Is this the starter?
Yes that is the starter motor.
You could test to see what voltage you are getting to the "small" wire to the starter when trying to start the car......or pull it and have it tested.
If you have the factory radio, when you remove the battery cables you might need the radio code to get the radio working when you re-connect the battery cables.
Old Jul 19, 2015 | 06:51 AM
Lost Again's Avatar
Yes, then there is another at the bottom.
Old Jul 19, 2015 | 08:05 AM
Lost Again's Avatar
Well, we tried.
I'm not a very big guy and getting kind of old (45~50). So I've learned to use leverage, one of my "best friends" is a piece of black pipe, found at almost any "home store", about 2 foot long. In tight spaces you can slide that pipe over a 3/8 ratchet and give it a go.
Anyway, don't let this turn you off from giving it a "go" next time something comes up.
Old Jul 19, 2015 | 10:10 PM
holmesnmanny's Avatar
That really sucks you had to pay someone 374 to swap that out. It's basically two bolts, a nut and a connector. You really just need a $75 set of tools and you can do a lot of basic things like swapping out a starter. The only thing you would have to worry about is making sure the negative battery terminal was disconnected before you started working on it.
Old Jul 21, 2015 | 10:38 AM
Is the green immobilizer light turning on when you try to start it ?
Old Jul 21, 2015 | 11:20 AM
tim73's Avatar
That really sounds like battery cables. If you havent already, unbolt them and clean both the inside of the cable...and the battery post. Then add some electrical anti corosion grease.
magpie.1234
Jul 24, 2015 02:19 PM
cfauvel
Oct 25, 2013 09:12 PM
mars
Mar 30, 2008 04:17 PM
tlovaj
Aug 23, 2007 04:17 PM
madhatter07
Jan 6, 2004 10:59 PM
