Idle for a second then dies
Old Jul 17, 2015 | 09:31 PM
Giannie11's Avatar
Default Idle for a second then dies
Did a b20 swap in a 94 del sol si. Changed starter and fuel pump. The car only starts if you take the intake off and cover the throttle body completely with your hand then shuts off around 1-5 seconds. The car seems to be running lean. Vacuum leak? Can't find one, especially with the car staying on that short. Tips? Ideas?
Old Jul 18, 2015 | 08:06 AM
Giannie11's Avatar
Default Re: Idle for a second then dies
Could that also be compression? Even though I just bought the engine from the jdm shop? 30-60k miles on a crv? I'm sure nobody beat on it for the engine to have any sort of problems
Old Jul 20, 2015 | 05:26 AM
09chaplak's Avatar
Loves Tossing Salad
Does it start with a little bit of starter fluid?
Old Jul 20, 2015 | 05:50 AM
cafrog's Avatar
Seems weird that plugging up the entire TB helps. Makes me think a Huge vacuum leak.
Check for spark and fuel after you look at all vacuum lines.
Scott Little
Nov 12, 2015 01:06 PM
sleutho
Honda CR-V & Element
Oct 28, 2013 10:32 AM
schools94
28
Jul 21, 2010 07:43 PM
cfauvel
11
Jun 8, 2009 10:19 AM
B20DA08
Apr 29, 2008 08:53 PM
