Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2005 Honda Odyssey door problem
Old Jul 17, 2015 | 10:01 AM
Dnguyen21's Avatar
Default 2005 Honda Odyssey door problem
Hello, I have a 2005 Honda Odyssey driver side sliding door problem. The passenger works fine as it should, however the driver side will not open or close on its own, the door will latch if you close it manually but only when the switch up front is turned to the off position, also when it does latch it would suck the door in for about 2-3 seconds then about another 2-3 seconds later it will push the rear of the door back out a little and then latch. Does anyone know the problem for this?
Old Jul 28, 2015 | 01:54 PM
GTLARS's Avatar
Default Re: 2005 Honda Odyssey door problem
I would inspect the lower stainless steel runners. They can get dirty and cause the door to stop working. While down there you should check the plastic roller to make sure that it isn't broken or missing. Do the same for the upper roller.
With everything clean and checked you should lube the runners. You should do the same for both doors. At least this will eliminate any mechanical issues as being the cause plus it needs to be done occasionally anyway.
Good luck.
ucf1975
Aug 17, 2013 06:16 AM
rayaman2
Mar 16, 2011 11:36 AM
2005avtj
Jul 30, 2008 07:56 PM
rlansdon
Jun 2, 2008 10:06 AM
buzzsawstan
Jun 30, 2004 11:49 PM
