Electrical problem w driver door
Old 07-30-2008, 08:00 AM
2005avtj's Avatar
Default Electrical problem w driver door
My g/f has a 94 civic ex and the drivers door has been giving us problem. The controls work fine when the door is closed, but when we open the door the power door lock doesn’t work. Also the speaker on the drivers door works intermittingly and the passenger side window does the same. I was wondering if theres a main switch or connector that controls these operations…
Old 07-30-2008, 10:19 AM
Former User's Avatar
Default Re: Electrical problem w driver door (2005avtj)
Check the door wire harness at the point where it exits the door and enters the car. You may find a damaged wire there.
Old 07-30-2008, 11:10 AM
2005avtj's Avatar
Is that a common problem at a quick glance it looks fine…the car has over 200k so I know wear and tear could cause a lose connection or some kind of switch problem…
Old 07-30-2008, 12:10 PM
Based on the information you provided, I think that location is a logical place to start.
Old 07-30-2008, 12:15 PM
OMGWTFBBQ!'s Avatar
Ummm, that first one is not a problem.
The locks dont work when the door is open unless you're holding one of the door handles open. Its the honda anti-idiot feature that makes it harder to lock your keys in your car.
Old 07-30-2008, 02:55 PM
2005avtj's Avatar
Default Re: (OMGWTFBBQ!)
Ok ill check it out when I get home…I know that you have to hold the inter door handle in order to lock the door but my problem is when the door is open and I do that it wont lock the other door…it will only lock the other door when its not wide open…on the ex model when you lock drivers door the passenger locks as well...it just seems like it lose it conection
Old 07-30-2008, 07:56 PM
OMGWTFBBQ!'s Avatar
Thats pretty weird.
kevpple
Honda CR-V & Element
07-07-2011 07:34 PM
dc2long
06-01-2011 02:53 PM
J.WOLFE~v1.0
12-23-2010 04:23 PM
lead23
02-23-2008 09:12 PM
Dropped90Integra
07-21-2005 07:50 PM
Quick Reply: Electrical problem w driver door
