Venting block from BS alignment hole.
I was wondering if it is a good/possible idea to setup a block ventilation from the balance shaft alignment hole. I have the KS BS delete full kit installed and no spray bar. My Oil pressure is like more then great, but I have no bottom end ventilation. Idk anywhere else to go from. Its just a built H22 NA and I'm running PCV for the top end. Idea's? Concerns?
When I first got my built block in and started I actually realized I had forgot to re-install the bolt from my old block to new, when I saw the leaking on first start, small puddle nothing big. But would this be to low of a spot to put one? and being in the back of the block accelerating maybe oil would sag to the back and go into it anyways. Thought's?
I'm not worried about it being that its a NA build, but I like to learn and do new stuff/projects, and if it helps then why not. Thanks.
shingles
Oct 22, 2002 08:25 PM
