i need professional advice and opinions please
Hi my name is Nate.i bought a 95integra last month.iknow the basics but was looking for a right and pro answer.the block says b16a no number after.the head says pr3-4 and 06.the ecu is a p30.jdm I think because its smaller.can u let me know wat I have exactly so I'm ready for rebuild.professional opinions on the motor.are they good or bad,jdm,sir.ive read alot of stuff bout them but still unsure.what car do u think it came off and year.thanks the sooner the response the better thanks ppl
So you have a B16 in an Integra and you're looking to rebuild it? I dont know what you're asking exactly...
Info directly from Wikipedia
B16A SIR-V (First Generation)
The first VTEC engine.
B16A found in:
1989-1993 Honda Integra XSi
1989-1991 Honda CRX SiR (EF8)
1989-1991 Honda Civic SiR (EF9)
Displacement: 1,595 cc (97.3 cu in) 1.6-litre
Compression: 10.2:1
Bore: 81.0 mm (3.2 in)
Stoke: 77.4 mm (3.0 in)
Rod Length: 134 mm (5.3 in)
Rod/stroke ratio: 1.745
Power: 158 HP @ 7,600 rpm & 111 ft·lbf (150 N·m) @ 7000 rpm
Redline: 8200rpm
Transmission: S1/J1/YS1 (4.4 final drive, cable clutch, optional LSD for YS1), Y1 (4.266 final drive, cable clutch, optional LSD)
ECU code: P-fk1 (DA6/DA8/EF8), PW0 (EF8/EF9/DA6), PR3 (EF8/EF9) OBD0
B16A found in:
Compression: 10.2:1
Redline: 8200rpm
I just don't know anything about the motor dont know if the head matches the block.what tranny it is.the code on the tranny is s80-2037652.is it a rare motor.bciz everything I've found about the b16a says its from an sir civic or xsi Integra.im not familiar with these older models.im somewhat new to this and sm learning new things everyday.the head says pr3-4. O/6 just any opinion of wat it is exactly will set me at ease thanks
Ok I think I found out wat Gen it is its a second Gen.i think the first gens thave the pgm fi intake manifold.now what I need to find out is what granny I have the serial code is s-80.anybody know or have any exp wit these motors to know which one I have or if its lsd equipped?
