Turn signal problem (solved)
Old Jul 12, 2015 | 05:00 PM
Azavala's Avatar
Default Turn signal problem (solved)
Okay this is probably something simple and I'm a idiot but I have 98 civic coupe and every time I turn on my left turn signal it blinks super fast but if I turn even my Parking lights on it'll blinker super slow. The right turn signal works perfectly fine. Any ideas? Thank you
Old Jul 12, 2015 | 08:47 PM
Former User's Avatar
Default re: Turn signal problem (solved)
Sounds like you installed the wrong bulb type.
Old Jul 12, 2015 | 11:48 PM
Azavala's Avatar
had the car for about 2 years never installed a bulb and for awhile it worked perfectly fine just a few months ago it started doing this
Old Jul 13, 2015 | 06:18 AM
Check whether any hazard/blinker bulbs are not working.
Old Jul 13, 2015 | 02:45 PM
Azavala's Avatar
i went and check the wiring and it hella butched like someone tried wiring in side markers or something but got it all fixed and works good now thanks man.
Old Apr 8, 2016 | 02:14 PM
frekboyartworld's Avatar
Default Re: Turn signal problem (solved)
Ive got the same issue in my 2000 EJ8, bulbs I bought were 1157A...grounds look good any other suggestions....only the left side is doing this
ridgeline08
May 29, 2011 10:38 AM
civiccoupe94
Oct 14, 2007 05:27 AM
magicguy
Dec 8, 2005 04:35 PM
eg8000rpm
Apr 27, 2005 12:37 PM
InTeGrA B18b1
Jul 14, 2004 05:50 PM
