eibach rear sway bar for 00 civic ex questions
Old Jul 10, 2015 | 04:21 PM
vega5415's Avatar
Default eibach rear sway bar for 00 civic ex questions
Will the 17mm eibach rear sway bar mount on a asr subframe brace? Yes or no? If not, is there a subframe brace that will allow eibachs rear sway bar to be mounted on. And with the car being used as DD and occasionally tracked does it need a subframe brace.
Old Jul 10, 2015 | 05:29 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: eibach rear sway bar for 00 civic ex questions
You would have to order the specific d-brackets and bushings for the anti-sway bar from Energy Suspension.
But these guys-> support@asrparts.com <-can better answer your question.
eH.
Old Jul 10, 2015 | 07:29 PM
eghatch9295's Avatar
Stancetard Hate Monger
you really should run a brace if using a rear sway bar. there are ALOT of ripped subframe stories on here from them. if you plan to auto-x, be mindful of the parts you install. something seemingly small can bump you into a much harder class.
Old Jul 11, 2015 | 02:28 AM
kristo's Avatar
Loved
The Eibach 17mill is meant to mount like the stock SI 13mill. No brace needed, but you will need the mounting hardware of the SI - it appears this does not come with the kit, see links below - did you even use the search or Google? You will also most definitely need backing plates, either ASR or homemade.
https://honda-tech.com/honda-civic-d...input-2650176/
https://honda-tech.com/suspension-br...-need-2897033/
Sway Bar Installation
Old Jul 11, 2015 | 09:28 AM
vega5415's Avatar
Thanks you guys appreciate the info
Old Jul 11, 2015 | 09:29 AM
vega5415's Avatar
eH.
I will thanks
Old Jul 11, 2015 | 09:55 AM
vega5415's Avatar
Yes, I have Googled searched this and these links have appeared and I have read them. And so far nothing really solid on anyone using this combination. I have email Eibach and ASR tech support and just waiting on them now.
Old Jul 11, 2015 | 06:36 PM
98civdx's Avatar
Master Detailer
You're correct, buuuut, I've been running a 17mm Eibach bar for something like a year with no backing plates. just nuts.
But definitely not a bad idea at all, I think they're only like $20 so not expensive.
Old Jul 15, 2015 | 05:20 PM
vega5415's Avatar
So I've emailed ASR and Eibach and still now response.
I have read on a another forum that I will need a special bracket that will have the 17mm sway bar mount to the asr brace. Has anyone else heard of this?
Old Jul 15, 2015 | 05:32 PM
tony_2018's Avatar
Fish Twig
So you just mounted on the rear subframe? No si brackets? Pics!
Old Jul 15, 2015 | 06:58 PM
98civdx's Avatar
Master Detailer
No "backing plates"... you still need to use the factory si brackets.
I've got pictures on my SD card which is no where to be found..
Old Jul 16, 2015 | 01:33 AM
kristo's Avatar
Loved
All this and more has been covered so many times ...
Like here, 98civdx, that was a fun and informative topic
Next time I'll stick with "Search, n00b!"
I've got pictures
You'v been promising to post these for years now
However, your option to use 10mm bolts and drill the brackets is not necessary. I'v run with the stock hardware (and ASR plates) the EK4 15mm for years now and it hasn't budged.
Old Jul 16, 2015 | 04:26 AM
tony_2018's Avatar
Fish Twig
Ok, you confused me for a minute. So you still needed the si brackets. Cool.
Old Jul 16, 2015 | 01:45 PM
98civdx's Avatar
Master Detailer
Lol I know.
I work 6 12's so I don't have much time, and I need to find a new camera. lol I will definitely try to get some her very soon, I promise!
When I did mine originally I wasn't able to get the ASR plates, so I made do. It may be getting a F7 brace/24mm soon though.
Yes, factory brackets are used. Just substituted a couple 10mm bolts.
Old Jul 21, 2015 | 09:51 AM
vega5415's Avatar
So it seems that I can mount a 17 millimeter sway bar to a ASR subframe brace but the 17 millimeter sway bar from Eibach requires there mounting brackets for it to fit correctly on a EJ 8.
I have come across a write up that has used the em1 mounting brackets and customized it to fit the 17mm ARB. They don't really go into too much depth on how they did it. Is there any one here that knows of a link that shows pictures and a better right up
Old Jul 21, 2015 | 03:11 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
You don't need a brace for anything smaller than 21mm.
Old Jul 21, 2015 | 05:28 PM
98civdx's Avatar
Master Detailer
There's nothing to customize (unless you go the route I did)
Get the Eibach 17mm bar, and get 17mm bushings for it. Use the original SI D brackets.
You DONT need anything special to do this. It's extremely simple. You're overthinking it and making it difficult.
Old Aug 18, 2015 | 07:30 PM
vega5415's Avatar
I tend to do that when I'm adding to the car, will it work, how did work, who's made it work, etc.
Thank for the info
Old Aug 19, 2015 | 06:06 PM
98civdx's Avatar
Master Detailer
so this thread popping up reminded me I needed to take pictures.
Good thing the car is up the air. I'll try to get some, or maybe a DIY or someshit up by Monday or Tuesday.
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
chinkyx90
14
Feb 22, 2009 08:45 PM
rupensane
Dec 1, 2008 07:00 PM
stuie08
Nov 25, 2006 02:30 PM
Slow_import
Suspension & Brakes
Feb 16, 2006 09:15 AM
