93' Honda Accord M/T - No crank, No start
hey everyone, this my time in the forums and I'm really you're able to help out tell me whether or not this is a post cause. Currently my 93' Honda Accord won't crank, turnover, start whatsoever; I've turned the headlights on to see if they dim while turning the key and nothing! Lights on the dash still come on though and the check engine light comes on and shuts off like it should. It started probably 2 days ago I drove to a buddies house to hangout and when I was fixing to i was denied. One thing to know is that my head gasket has been blown since i bought the car a couple of months ago (oily engine block) , but since then ive only had to replace the starter which i replaced again because it was under warrenty and i thought it was the problem (they did say the one i brought back was defective somehow; it had something to do with that spindle thar goes into the engine which was locked up im pretty sure they said) and a radiator hose the blew in me ( didnt fully replace the hose when it gave out the first time, but when i finally did i was driving long distance and the car locked on me after a little while of driving - breaks weren't working and couldnt gas it so i shut it off for a little in the highway and then restarted and it was dandy). With this current issue ive also replaced the ignition coil because it looked to be burning where the plug connected with it, and ill post a picture if i can (havent gotten any new plugs yet). Currently planning on looking at the distributor and main relay. Put curcuit tester on coil and distributor as well the starter, but with the starter i touched the conecters and with the coil and distributor ive only touched the bodies, but the light came on so.. Im not sure. Any questions or if you need more info ill be willing to provide when i get the chance
Old ignition coil<br/>
Coil plug
Pov of coil #1<br/>
Pov #2
Current distributor
You need to pull the small wire from the starter. Have someone try to start the car while you measure the voltage to the small wire.....are you getting battery voltage to that small wire?
I've used a circuit tester and all wires showed they were getting power, but i dont have the tool to measure the exact voltage
I actually had thr starter replaced when thebstarte first presented itself as it was under warranty and cost me nothing, but i was thinkin it mightve been not enough voltage, but puzzles me is that i was driving it maybe an hour two before and when i went to start again it just had nothing to give me.
Really wish you had a volt meter to measure the voltage, simple ones can be had for ~$5.
Check and clean the battery terminals, all ends of both cables and be sure the connections are clean and tight.
Have you tried to jump start it with another car? Sometimes the added voltage from another car is enough to "bridge" a weak connection and get it running.
Harbor freight has them for $5.99, if there isn't one near you - even walmart has them for less than $10.
And jumper cables, a cheap set is less than $10 as well.
Based upon your description of the battery cables and their connections.....they are my #1 suspect but that is a guess and don't do anything on a guess.
When you tried to jump start the car, was the ground clamp on your car on the battery or to the frame/engine?
But if it was the "clutch switch" you would not get voltage to the small wire on the starter. So I'll ask again "are you getting voltage to the small wire on the starter?"
Well I'm "spit balling" ideas/things to try without being able to actually test anything.
Sorry, just trying to help
When you used the test light.....were you using the battery ground as the "ground"? If so what happens when you use the "transmission case" as the ground.
To re-cap where I'm at....you have voltage to the small wire when trying to start but don't know "how much". So either the starter is bad, you would not be the first one that has gotten a "bad" one out of the box, or you have a bad/weak battery, or a bad weak battery connection - either the ground or the positive or both.....you do have a "screw" trying to hold one of the battery clamps tight
The "trans case" is just that.....the outside metal/alum case of the trans.
If you can, yes pull the starter and the battery and have them tested....if they test good at the parts store......stop somewhere and get a volt meter.
