92 integra rs, running really rich
Cant figure out why its running so damn rich, im getting 10mpg.
Its blowing black smoke, small amount at idle but a cloud of smoke if i open the throttle.
I changed the o2 with a working one, changed injectors, changed iacv, changed ect sensor, changed thermostat sensor, changed thermostat, changed the throttle body( for the tps), i even ran a chipped p28 for a b16, to see if it will lean it out a bit and still running rich.
The only thing left is timing, the ignition timing is at 4 degrees with the dizzy all the way at advance, so i believe the mechanical timing is off.
When i was adjusting timing on my b16 swap, the ignition timing was off by alot too, but it wasnt running rich like this car is. What else can i check for? Need some suggestions
Jet Black
Nov 25, 2006 06:49 PM
