97 Civic HX A/C compressor clutch not stopping
97 HX
I was fixing my a/c the other day, draw the vacuum, jumper the pressure switch to service the R-134a. Once i was done servicing. with the jumper removed, i noticed my a/c compressor clutch always engaged. next stop and go like normal compressor clutch.
I'm reading the wiring manual, does anyone know what stopping the clutch to engage?
thanks
thanks
What did you fix and why?
There should be no need to jump the pressure switch.
The A/C thermostat.
...jumper the pressure switch to service the R-134a.
i noticed my a/c compressor clutch always engaged. ...does anyone know what stopping the clutch to engage?
If you had followed the helms manual than you should know that you don't need to jump the clutch and to add the proper amount.
Registered user
19
Nov 5, 2016 11:54 AM
johnone
14
May 22, 2014 09:17 PM
