2000 EX Coupe AC Charging
Old Jul 6, 2015 | 04:46 AM
zturek's Avatar
Default 2000 EX Coupe AC Charging
2000 EX Coupe
Trying to add more freon to the low side with AC on high setting.
It does not seem to be taking in any freon because the pressure gauge
does not increase.
I am using a single gauge setup you get from Walmart problably not
the best.
I am also interested in getting a good set of gauges for monitor low
and high side. Please suggest a set to purchase, please not
harbor frieght.
Thanks in advance
Old Jul 6, 2015 | 07:01 AM
Former User's Avatar
Default Re: 2000 EX Coupe AC Charging
Don't add refrigerant unless you have diagnosed low refrigerant levels using a manifold gauge set. Go to Amazon and do comparison shopping there and also read reviews.
Old Jul 12, 2015 | 12:28 PM
zturek's Avatar
Got the gauges
Ran for twenty minute. Outside air temp 89
AC fan at Max.
****UPDATED info engine RPM 700 need to be about 1500
Probably should have not at freon before I got the good gauges.
What are the pressure reading suppose to be?
Inside temp 60 max fan non recirculate
Last edited by zturek; Jul 13, 2015 at 04:03 AM. Reason: Update RPM so other people reading this will know
Old Jul 12, 2015 | 08:29 PM
The engine should held at 1500 rpm when taking the pressure and temp readings.
I assume the condenser fan runs.
Old Jul 13, 2015 | 04:02 AM
zturek's Avatar
Thanks Ron I will have to retake the pressure readings the engine was
only at 700 rpms.
The condensor fan is running all the time at 700rpms
blacktibby07
16
Mar 5, 2011 05:50 PM
D16SohcVtec
Jul 28, 2009 07:38 PM
koondawg
Acura TL, RL & ZDX
Jul 12, 2005 08:37 PM
