h22 accord hesitation/bogging
Old Jul 2, 2015 | 02:23 AM
hondamyheart's Avatar
Default h22 accord hesitation/bogging
Hi,
I have a 94 accord with h22 swap. Recently it starts to hesitate and bogs down. I checked the following:
O2 sensor (replaced)
recalibrated TPS
Fuel filter and fuel pump replaced
the wires that runs out from the Injector resistor box all oxidized. I was thinking maybe it is causing this issue? where are this wires goes? Do i need to remove the dashboard or it is under the driver side?
Old Jul 2, 2015 | 10:09 AM
holmesnmanny's Avatar
Default Re: h22 accord hesitation/bogging
What do you mean by oxidized ?
Old Jul 2, 2015 | 04:23 PM
The color of the copper turned to green.
Old Jul 2, 2015 | 05:56 PM
Tachi's Avatar
Has the EGR stuck open? The EGR manifold can get dirty as well. How does it perform at WOT?
Old Jul 2, 2015 | 06:07 PM
v4lu3s's Avatar
RTFM
when does it hesitate and bog? check engine light on?
Old Jul 3, 2015 | 10:56 PM
The EGR is removed am using a block off plate. It runs like crap at WOT.
The car sometimes runs perfect and sometimes it bogs and hesitates all the way.
Old Jun 10, 2016 | 11:22 AM
Javier Alvareng's Avatar
Im haveing the same problem just droped a h22 in a 97 ek. New dizzy and bogs out in gear on take off revs up high in nutrul any help
Old Jun 10, 2016 | 02:21 PM
The hesitation on an h22 swap can be caused by using non-shielded wire for the added knock sensor wire. It must be shielded wire or it can pick up radio intereference.
piropal
Nov 7, 2007 09:27 AM
