LsVtec dudes
Old Jul 1, 2015 | 06:13 AM
HuckelberryT's Avatar
Default LsVtec dudes
B18b with a Gsr head can I use the Ls thermostat housing or do I need to go with a different setup? Also wanted to hear some opinions on shot peening the rods, should I save the $60 if I only plan on taking her up to 8000? Granted I have already upgraded to Arp rod bolts
Old Jul 1, 2015 | 03:26 PM
king06's Avatar
Default Re: LsVtec dudes
I'm pretty sure you can use any b series thermostat housing.
And I wouldn't shot peen them, as long as you got the rods resized you should be fine.
I would rather spend some money on spring and retainers.
Old Jul 4, 2015 | 05:15 AM
blackeg's Avatar
word up
Old Jul 6, 2015 | 07:53 PM
4imports.net's Avatar
The arp 2000 rod bolts should be sufficient enough for that low of a rev limit. Make sure to upgrade to a vtec waterpump and oil pump as well.
Old Jul 7, 2015 | 04:24 AM
Ok so I bought some Acl Aluglide bearings and after receiving them I realize that the rod bearings have holes drilled into each half. I know the factory ones did not have these holes. Should I go ahead and use them even though the holes are literally useless with the stock ls rods?
blackcrx16
Oct 19, 2007 01:53 PM
EG93si
Jul 8, 2006 12:19 PM
inFamousOneSix
Jul 9, 2003 12:29 AM
tinkerbell
Jul 16, 2002 07:39 PM
