CA Smog help
Old Jun 30, 2015 | 08:58 PM
Jamm_95's Avatar
Default CA Smog help
So I have a 1994 prelude with an h22a 9:1 compression, egr ports were cleaned a couple months ago and I just did a full tune up (o2 sensors, cap/rotor, wires/plug) and I literally had my cat replaced yesterday and this is the third time I failed smog and my temporary permit is about to end. The first time I failed smog for high everything, then 2nd time I added some guaranteed 2 pass stuff and I failed again but it made it worse, gross polluter on both 15 and 25 mph and now today after tune up and replacing cat, I failed by being gross polluter on HC and CO on 25mph only
First test
3rd test after replacing cat and full tune up
Old Jul 1, 2015 | 01:42 PM
tamboo's Avatar
10 Year Member
Default Re: CA Smog help
clean injectors, iacv, fitv
check vacuum/exhaust leaks
new air & fuel filters
adjust valves & idle
check timing
change oil
Old Jul 1, 2015 | 01:54 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
You need to adjust your ignition timing to within spec, and then adjust your idle.
Old Jul 1, 2015 | 06:38 PM
holmesnmanny's Avatar
Depending on how far off your ignition timing is, it's possible bringing it to -15 will make you pass.
Nicks95GSR
May 21, 2008 07:37 AM
emtatlanta
May 10, 2006 07:45 PM
sohc90rex
16
Mar 31, 2005 07:27 PM
Blackhtch
46
Dec 30, 2004 12:02 AM
GSRacer1
Oct 9, 2003 10:40 AM
