Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help
Old Jun 30, 2015 | 07:27 PM
94 Cd7's Avatar
Default Help
I'm doing an h22 swap to my 94 stick accord. Problem: the engine was on automatic transmission I have stick. I know the F and H series are compatible but will it matter if the H was automatic ?
Old Jun 30, 2015 | 10:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help
Yes, the passenger side engine mount bracket welded to the frame rail is wrong... you will need to purchase the original weld-on bracket for a manual transmission car and have it welded on... after removing the spot welds and prying off the original one. A splash of paint rounds out the fix. You will also need to use a manual trans bracket.
Old Jul 1, 2015 | 12:13 PM
94 Cd7's Avatar
Default Re: Help
Mine is already manual. Your talking about the mount brackets on the actual engine correct? The engine I wanna put in my accord is auto but I'm hoping if I do have to convert the engine to manual it won't be a pain in my ***
Old Jul 2, 2015 | 06:30 PM
m4xwellmurd3r's Avatar
Default Help
Swap the flywheel and clutch to the new engine and you should be good to go.
That's if you're using the manual trans too
If you're doing what I think you are. Manual chassis, manual trans, auto engine
truevietluv636
14
May 17, 2023 12:26 PM
EFbattleSedan
Jun 30, 2013 06:07 AM
whatafool
May 28, 2006 09:55 AM
bgoetz
Oct 1, 2004 02:40 PM
SlowTec
Oct 2, 2002 02:46 PM
