OIL CATCH CAN BUNG SIZE FROM VALVE COVER SIDE TWO FEEDS NO RETURN
-10 and from CC to VC "straight" from VC TO CC 90* or 45* fittings, by no returns you mean nothing from the block. so do as I said those are the fittings I have messed with -AN fittings plenty.
yeah i dont want to recycle any of the oil that it caught, do you know how to have a line for the crank case or is that what the pcv does?
do you know what id need to do for crank case to a catch can? ive read that you can use a can instead of the black box thing on the box and it works better... it didnt go to far into detail on that post also i just read this... whats your opinion on it "Many 10AN systems are in use and very adequate up to a certain point of back pressure and oil travel through the system.
The larger line will reduce travel of oil and create a greater vented crank case for better ring seal"
slippery seal
Welding / Fabrication
Jul 1, 2015 02:04 PM
TravisBiggie
Jul 3, 2012 10:48 AM
kreatekustomz
May 21, 2010 09:11 PM
