Shaking when accelerating
Old Jun 29, 2015 | 03:56 PM
vtrp2008's Avatar
Default Shaking when accelerating
94 civic coupe, installed the jdm b16a in it, new axles, ball joints, hasport mounts, as i accelerate i get a shaking through the front end up til ablut 30-40 mph then its smooth.. I did order a half shaft and the seal was ripped and looked like a used one, could that half shaft be bad? Causing this shaking? I dont have any play in the control arms, tie rods or ball joints, its got me stumped... Any. Help is appreciated thanks HT
Old Jun 29, 2015 | 03:57 PM
vtrp2008's Avatar
Default Re: Shaking when accelerating
Its a 94 integra half shaft
Old Jun 29, 2015 | 07:00 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Did you pull on or seperate the joint in the axle while installing it? Sounds like a bad axle.
Old Jun 30, 2015 | 07:08 AM
Preteclude's Avatar
I have a vibration from coming my front end as well. So I pulled it into the dealership after work and my right haft shaft has about 1/4-1/2" play in the inner joint. So that would be where is start all over again. Could be a bent wheel too.
Old Jul 1, 2015 | 08:44 AM
vtrp2008's Avatar
Just looked and my drivers side axle isn't straight, it's warped I had it spinning in the air and it was noticeable smh this is the 2nd brand new axle from OReillys
Old Jul 1, 2015 | 01:44 PM
B serious's Avatar
You pulled on it.....
darot
Transmission & Drivetrain
Jul 18, 2009 08:22 AM
Philip
14
Dec 4, 2005 08:41 AM
dubbedcorde
10
Jan 6, 2005 04:16 AM
full Circling
Jul 19, 2004 08:20 PM
