NEED HELP steering column
Old Jun 28, 2015 | 10:13 AM
c_logoteg01's Avatar
Default NEED HELP steering column
This is out of my 01 integra, I'm switching steering columns but I can't figure out how to get the shaft outwith universal joint on it, any help would be appreciated
Old Jun 28, 2015 | 10:36 AM
cafrog's Avatar
Default Re: NEED HELP steering column
Remove the joint/yolk from steering rack? Thats very easy but you must be speaking of something else? I cannot see your picture.
Old Jun 28, 2015 | 12:18 PM
Old Jun 28, 2015 | 12:58 PM
v4lu3s's Avatar
RTFM
are you trying to completely disassemble the steering column? usually you just take that whole pile of stuff out and swap in the new one. i do not really understand what you are trying to do.
Old Jun 28, 2015 | 01:38 PM
I have another whole steering column minus the part between my fingers
Old Jun 28, 2015 | 05:12 PM
v4lu3s's Avatar
RTFM
well good luck might have to learn how to press the bearings off and replace them.
Old Jun 28, 2015 | 06:14 PM
holmesnmanny's Avatar
There are two bolts that go through that joint. Remove the bolts.
Old Jun 28, 2015 | 06:28 PM
cafrog's Avatar
New territory for me. Have you looked from the steering wheel side? Maybe the piece is long?
Old Jun 29, 2015 | 04:28 AM
I got it. .. it's setup kinda like a Ford fuel line, I cut a piece of a pop can and slid it down in the outer shaft and it pulled out, thanks for the input anyway
dr_latino999
Jun 17, 2008 09:59 AM
RanCRX
10
Oct 9, 2007 05:44 PM
na4now
Feb 7, 2006 10:46 AM
AJxr
Jan 8, 2006 11:08 AM
Sean EH2
Jul 31, 2003 04:35 PM
