Wiring help for hatch (not my specialty)
hey guys, recently bought two EG hatchs. A 95 eg vx d15z1, and a 94 eg si shell. Im swapping the d15z1 into the si shell. Heres my problem: the previous owner of the si cut the harness in multiple spots throughout the car. What is the best way to go about fixing this? I do have the complete d15z1 harness and ecu. I don't not have si ecu.
thanks
-phill
thanks
-phill
after some digging through the bay, i found out the only thing he cut was the ecu wires and the engine harness. which hopefully this leads to a more relieving question.. As far as i can tell almost all of the connectors look the same. So i should be able to run my d15z1 ecu.. to my d15z1 engine harness.. to the d16 connectors (driver side).. to my d15z1 fuse box (under steering wheel).. if the d15 fusebox will fit all the connectors of the d16 body.
correct me if I'm wrong. This is my first time.
okay.. good news
Now that I think of it the si has power windows and locks. You will need to figure out what way is best for you as you have some wiring that will need to be done.
The Z1 should also have EGR wiring as well that the Si won't have. Not sure if those are prepinned on the 92-95 harnesses but if not you'll have to wire that as well.
Thanks guys
but did some more finding out tonight, basically.. he cut the air bag harness, and the the wires to i think what is call the shock tower, (the wires from the ecu that go through the fire wall to the engine bay). The wires from the ecu that turn left toward the driver side are still intact (as far as i can tell). not worried about air bag atm.. was thinking about cutting my current harness and rewiring connectors. but don't want to risk it so ill just take the time and pull and swap both complete harnesses.
integranator
Oct 24, 2007 09:11 PM
5poonhatch
May 30, 2005 06:28 AM
