honda bounce
Old Jun 27, 2015 | 05:22 PM
raverx3m's Avatar
Default honda bounce
so my car is bouncing
when I take off at the light in first gear
if I shift normally it only does it in first gear.
if I shift hard I hear the typical bowwowowowowbrrrrrrrrrrrrrwaaaaaaaaaaaa( best I can describe lol) that you hear in every Honda racing video
stock motor stock mounts. stage1 exedy clutch about 50-60% as far as I know is good no busted springs
last car that had the bounce turned out to be bad TPS.
this car is the fuckmobile that been wasting my time for almost a year so everything is good in this. I know every sensor works because I tested it over and over troubleshooting another problem.( distributor was bad)
so it bounces pretty bad when I take off. its kindof embarrassing looks like im a noob driver.
I checked the mounts and they are all good. no rips on either of big mounts
now I have few questions
1 can a mismatched clutch disk and pressure plate cause this. because the clutch engages rather quickly for stage1 exedy. I had less issues with act stage 4 in same car that I drove without bouncing.
2 are the torque mounts supposed to be centered or it doesn't matter?
3 how can I test the engine mounts to see if they are possibly blown out. it idles smooth. doesn't wobble when I rev it with throttle cable. doesn't move when I try to shake it by hand. and visually the mounts are good.
globy123
56
Sep 16, 2018 05:53 AM
Stopsign32v
May 14, 2011 09:27 PM
typhoon
Nov 15, 2006 09:13 AM
sivik_outkast
13
Jul 14, 2006 04:43 AM
ch0
May 16, 2005 10:39 AM
