Help - radiator fan will not run. Searched forum but no solution.
Old Jun 24, 2015 | 06:48 PM
Mootspoints's Avatar
Default Help - radiator fan will not run. Searched forum but no solution.
1998 Civic EX overheats at low speed due to radiator fan not running. I replaced the temp switch and thermostat after verifying the fan will run with a jumper at the switch connector on harness. Also swapped relays with no result. I've searched but can't find a solution. Help!
Old Jun 24, 2015 | 07:23 PM
JarvisW's Avatar
Sol to Sol
Default Re: Help - radiator fan will not run. Searched forum but no solution.
Verify the switch opens/closes at temp? Bleed it correctly? (someone quoted "if it seems like it is taking a long time, you are only half way there!)
Old Jun 24, 2015 | 07:33 PM
Former User's Avatar
Bleed the cooling system. Does leaving the switch jumped prevent overheating?
Old Jun 25, 2015 | 01:56 AM
Yes, if I leave the jumper in the connector it will not overheat. With the temp switch plugged in the Gage can go all the way up and the fan will never turn on. How do you think bleeding may be causing it? Not enough coolant in contact with switch?
Old Jun 25, 2015 | 02:17 AM
HondaPartsHero's Avatar
Technical Hero
If you have air in the system the switch will have trouble sending signal.
Old Jun 25, 2015 | 02:45 AM
Yes
Old Jun 25, 2015 | 03:16 AM
Bingo. That worked. The fan is running. Now I just need to watch it and make sure it's not eating coolant. Thanks guys.
Lando555
10
Mar 12, 2019 04:27 PM
Nichol Viena
Aug 15, 2015 04:52 AM
hotcivicsi
19
May 15, 2009 01:54 PM
HybridKOOP
Aug 14, 2002 11:08 AM
JDM_Type-R
Jun 16, 2002 08:31 PM
