Coilover clunk noise- Integra ls 2000
Old Jun 24, 2015 | 05:40 PM
theojo07's Avatar
Default Coilover clunk noise- Integra ls 2000
Hey guys, recently bought and installed some Skunk 2 Pro C 2 along with the pro series camber kit. After driving it for a few days I notice a clunk sound coming form the front passenger side of the car once I hit a bump or a pot hole. If anyone can assist with resolving this issue it will be much appreciated thanks.
Old Jun 25, 2015 | 06:16 AM
EnjoyTheRideDC2's Avatar
Default Re: Coilover clunk noise- Integra ls 2000
Who did the work installing the coilovers and upper control arms?
Old Jun 25, 2015 | 06:25 AM
cafrog's Avatar
Take a crowbar and pry it around a variety of suspension parts to see if there is play in any of it. Check all bolts to make sure they're tight.
Has the car been aligned? I truly doubt this is the issue but they may see a mistake or something loose.
Old Jun 25, 2015 | 09:39 AM
I personally wouldn't touch the car if the OP paid to get the work done.
I'm not sure prying on suspension parts would do any good, especially with the car on the ground. Even raised off the ground, you wont find anything significant.
The clunk may be from incorrectly installed upper control arms or incorrectly adjusted coilover perches. It would help to know who did the work on your car.
If you paid a shop to do the install, bring it back to them and have them take a look at it. If you did it yourself, make sure the spring is snug between the perch when the suspension is unloaded. With your upper control arms, make sure the UCA bushings are clocked correctly when the arm is tightened down to the bushing itself.
Old Jun 25, 2015 | 06:45 PM
cafrog's Avatar
Wording makes it seem like he did it himself.
Pry bar to check bushings. It's something I always do and have seen countless mechanics do to check clunky and wobbles. The coilovers could be the issue or the new parts have risen other issues that were not detectable before.
Old Jun 25, 2015 | 11:23 PM
If the OP had a constant vibration or shake in the steering wheel, then a pry bar may be useful in finding a loose or worn component. But whatever the case may be, seems like the OP doesn't feel like participating in his thread anymore.
Old Jun 26, 2015 | 05:18 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
One thing you should never do is go check it yourself.
"My car is making a noise". Easiest and most straightforward way to solve the problem is by posting on the internet. Duh.
Old Jun 27, 2015 | 12:04 PM
wunfstgsr's Avatar
Loved
Community Favorite
$5 says its the lock rings on the sleeve that came loose! Use the special wrench and check those to see if there tight!
Old Sep 20, 2015 | 03:49 PM
theojo07's Avatar
hey guys i know this reply is past due, but ive just been busy with other things lately. Anyways it just needed a bit tightening. Thank you all for your insight it has been much appreciated.
Old Sep 20, 2015 | 07:18 PM
wunfstgsr's Avatar
Loved
Community Favorite
There you go now you owe me $5
Frank Allen
Aug 31, 2013 01:47 AM
jayare05
Mar 22, 2009 11:24 AM
Tuesdaynightfever
23
Dec 5, 2006 06:34 PM
timaa66
Sep 22, 2006 01:12 PM
vgsr
May 29, 2005 09:26 PM
