Cruise control in EJ6 - no a hole in the firewall
Old Jun 23, 2015 | 01:40 AM
Uzumymw's Avatar
Default Cruise control in EJ6 - no a hole in the firewall
Hello, I want to install in my Civic '00 cruise control, but I have a problem because I don't have a hole in the firewall to install a second cable from the actuator like this:
Here is my firewall:
I need to cut a hole mount, or maybe it was the second type of cruise control?
Old Jun 24, 2015 | 07:51 AM
Uzumymw's Avatar
Default Re: Cruise control in EJ6 - no a hole in the firewall
Anyone can help ?
Old Jun 28, 2015 | 12:17 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
I think you know the answer to this already: Cut a hole. There is no alternative.
Old Jun 28, 2015 | 01:33 AM
Uzumymw's Avatar
But why in my car I don't have a cap in the firewall for the cruise? I know that there are two types of brain for cruise control, maybe there 3 type for civics 99-00?
Old Jun 28, 2015 | 03:04 AM
deschlong's Avatar
Loved
Community Favorite
There is always a cable that goes to the pedals, can't get around that. I'm going to guess you're not in North America, right?
Old Jun 28, 2015 | 03:21 AM
Uzumymw's Avatar
You're right, Europe
Old Jun 28, 2015 | 03:29 AM
deschlong's Avatar
Loved
Community Favorite
Yeah then get out the hole saw. Touch up the exposed metal when you get the hole cut. Might need to notch out the hole like the throttle cable one. Thankfully that can be your pattern to copy. The holes are identical in size and shape IIRC.
Old Jun 28, 2015 | 03:45 AM
Uzumymw's Avatar
So without drilling there's no way, too bad. Thank you for help
Old Jun 28, 2015 | 05:08 AM
hondamark35's Avatar
it's the only way to get a factory setup to work. however, like the accords and other various models you can run the actuator cable to the throttlebody rotor. an accord throttle body should be a direct bolt on. this would be the best way to get the correct rotor setup. then you just need to mount the accord type actuator and the rest is just wiring as usual.
see the second rotor in the TB below:
Old Jun 28, 2015 | 05:46 AM
Uzumymw's Avatar
Cool! I am glad that there is another way. I wonder if this part of the throttle from Accord will fit to my Civic
Old Jun 28, 2015 | 10:50 AM
I wouldn't recommend swapping just the rotor. this is a factory set and calibrated part of the assembly that can cause problems if not done right.
swapping the complete throttle body assembly from accord (F-series) to civic (D-series) should only require a new gasket and some simple wrench turning. some even come with the bracket bolted to the side.
I actually have one i'd like to get rid of but you said your in Europe so shipping would probably be too much.
Old Jun 28, 2015 | 11:39 AM
Uzumymw's Avatar
Unfortunately my throttle is different than in Accord because my throttle body has integrated IACV
JONESn'
Feb 15, 2013 01:21 PM
category5 SI
Dec 21, 2008 04:41 PM
vtecpsyco
Jul 31, 2004 03:12 PM
hoophype84
Apr 1, 2004 02:18 PM
