HELP!!!! electric gremlin?
Old Jun 22, 2015 | 05:03 PM
charliecd5's Avatar
Default HELP!!!! electric gremlin?
So this started about a month ago, i'd be driving and i'd hear a click behind the dash on the pass side and my abs light lit up but it acted as if I had just turned on the ignition without firing the engine, gauges would reset and the stereo would click off then back on, and sometimes, more frequent now it'll just continue too click keeping the stereo off, the fuel pump will rarely click on again as if im just turning on the ignition, and the door locks will lock and un lock during this as well as the alarm will chirp, and I cant seem too figure this out, if anyone can point me in the right direction it'd be outrageously appreciated!!! thank you
Old Jun 25, 2015 | 03:44 AM
slowcivic2k's Avatar
Default Re: HELP!!!! electric gremlin?
Pontiac vehicles suffer from this a lot.
Start with providing a detailed history of the problem, and when it started.
You want an answer, I want information. Otherwise, consult the diagnostic 8-ball.
Automotive Diagnostic 8 Ball Automotive Video
There is no such thing as an electronic "gremlin".
Old Jun 28, 2015 | 07:41 PM
charliecd5's Avatar
ok so the car is a 95 Honda accord ex f22b1 sohc vtec with 5 speed standard transmission. First started memorial day weekend. started not very ofted and progressed too more and more frequent.
main symptom is the clicking behind the dash on the pass. side, and with the clicking the stereo is shut of and resets, resets all the gauges, and triggers the ABS dash light too come on, which sometimes will go out right away, and other times the light will remain lit. if im at a stop and its clicking I can feel a slight bump in the break pedal in sequence with the clicking. There are times when It will click just once, and will stop and then theres other times when the clicking will continue for long periods. also at times it will trigger the alarm too chirp periodically, and the doors will lock and unlock. the only thing that ive put with this issue is when I push the clutch in, the vibration from the gear change and increased RPMs will set it off, other than that it seems totally random. Doesn't affect the running or driving of the car
Spawne32
Jun 21, 2009 07:13 PM
FlipSide24
Apr 24, 2009 06:38 PM
IntegraChick
Oct 31, 2005 07:18 PM
SOKDO
Apr 17, 2005 10:51 PM
accordexchange
Dec 10, 2003 07:27 PM
