A04 ECU in a 01 Integra LS
Old Jun 20, 2015 | 12:29 AM
frankiecutz's Avatar
Default A04 ECU in a 01 Integra LS
long story short I'm putting a GSR motor in my 2001 Integra LS. I found a GSR ECU on Craigslist with the part number 37820-P72-A04. Did some research and found this post https://honda-tech.com/acura-integra...5-ecu-2630208/
If I read correctly it sounds like I need an A05 ECU because I have a 2001. I'm using the same wiring harness currently on the car. Am I reading this correctly? Somewhere on the post there is mention of a harness. Does this exist?
Old Jun 20, 2015 | 03:08 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: A04 ECU in a 01 Integra LS
There is a clear physical difference between OBD2A and B ecus, but unless you're going to have a dealer rekey you for the immo, the a04 is ideal. You can use an OBD2A to OBD2B jumper harness. Personally I would use an OBD1 ecu so you can tune it, but that's just me being a tuner.
Old Jun 21, 2015 | 08:41 AM
Thanks for the reply. Yea I'm gonna go ahead and buy the A04 and the jumper harness.
ek9ina
Mar 13, 2014 09:30 PM
feriotypeR
Jun 16, 2009 12:20 AM
jdm_xsi206
May 9, 2009 09:58 PM
93dagsr
Jul 31, 2007 01:52 PM
sik96teg
16
May 26, 2006 11:23 AM
