Will Spoon Calipers clear the 15" UKDM rims?
Old Nov 4, 2002 | 05:27 PM
B2FiNiTY's Avatar
Default Will Spoon Calipers clear the 15" UKDM rims?
Curious.
Old Nov 4, 2002 | 05:36 PM
MiraiZ's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (B2FiNiTY)
I think you will need 16" wheels
Old Nov 4, 2002 | 05:43 PM
Joker's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (MiraiZ)
Due to the fact that they clear the USDM stock wheel, I don't see why you'd have any trouble Den.
Greg - who just went to Spoon's web site, and couldn't find the answer...
Call Brandon or Dave at http://www.inlinefour.com tomorrow, and they can tell you for sure
*edit* Their site only mentions "These calipers will only fit Type-R or Prelude sized rotors. Sold as a front pair." Doesn't mention anything about wheel's. Your best bet would be to call them
[Modified by Joker, 6:46 PM 11/4/2002]
Old Nov 4, 2002 | 05:46 PM
B2FiNiTY's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (Joker)
It depends on the offset and spokes...
The calipers don't fit under the Millenia rims because of the spokes.
Old Nov 4, 2002 | 05:47 PM
DC2#309's Avatar
New User
I believe it will, because it has exect same clearance with compared to EK9 stock rims which is USDM DC2.
Old Nov 4, 2002 | 06:32 PM
DC2#428's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (DC2#309)
Old Nov 4, 2002 | 07:20 PM
Q-OnE's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (DC2#428)
i would think you would need 16's no less. look at how our type r caliper is so close to hitting the wheel already. i have a hinch it won't fit 15's
Old Nov 4, 2002 | 07:30 PM
Ferrell's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (NAgs-R)
itrsport doesnt have a problem with his under the usdm wheels correct?
someone posted a pic a faw days about about someone spoon calipers rubbing with the millenia wheels?
Old Nov 4, 2002 | 07:32 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (Ferrell)
Asspenny had a problem with the spoons rubbing the millenia spokes, i think he solved it with a 6mm spacer(or five).
Old Nov 4, 2002 | 07:33 PM
TypeR 599's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (Rguy)
well dennis, if it doesn't fit under those rims, trade me for my US rims that will fit it
Old Nov 4, 2002 | 07:49 PM
SoCal ITR's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (TypeR 599)
yaya, so I can put the JayDeeM wheels on mah kaa.....
Old Nov 4, 2002 | 07:52 PM
B2FiNiTY's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (SoCal ITR)
I know 100% for sure they fit under stock rims...but what about the UKDM!?
Old Nov 4, 2002 | 07:54 PM
MiraiZ's Avatar
spoon has two sets of calipers out now...I think one is a twin pot the other is a sing pot...I'm pretter sure the twin pot won't clear 15" rims....not sure about the single pots though
Old Nov 4, 2002 | 08:01 PM
B2FiNiTY's Avatar
So which version is the usual version they sell? I never heard of this single pot one.
Old Nov 4, 2002 | 08:14 PM
SiB16AVTEC's Avatar
The twin block is the usual version they sell. The mono block is generally a universal application, particularly the S2K and the DC5s.
Old Nov 4, 2002 | 08:19 PM
B2FiNiTY's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (SiB16AVTEC)
Oh ok...I'm inquiring about the twinblock.
Old Nov 4, 2002 | 08:36 PM
DC2#428's Avatar
B2 are you using the UKDM/AUSDM wheel?....
Old Nov 4, 2002 | 08:38 PM
B2FiNiTY's Avatar
Will be using the UKDM
Old Nov 4, 2002 | 08:39 PM
evil vapor's Avatar
Curious.
nope, will NOT fit, US spec wheel will work, you'll need spacer for UKDM wheels.
Old Nov 4, 2002 | 08:40 PM
DC2#428's Avatar
sweet...
evil vapor's Avatar
Default Re: Will Spoon Calipers clear the 15" UKDM rims? (vapors2k)
and this is running the older caliper design, not the monoblocks which do not use adapter/brackets.
Old Nov 4, 2002 | 08:59 PM
B2FiNiTY's Avatar
Serious? fugg...
Old Nov 4, 2002 | 09:06 PM
evil vapor's Avatar
Serious? fugg...
yeppurs, been down that road 2 years ago when I was running ITR suspension/hubs 5 lug and all and was experimenting with wheel options for the Si and I test fitted the UK spec wheels and it would not clear, maybe 3mm off.
Old Nov 4, 2002 | 11:05 PM
B2FiNiTY's Avatar
That's some bad news...I don't like running spacers.
Old Nov 4, 2002 | 11:14 PM
Mario's Avatar
Blah, at least the spacers won't be as thick as this...
Thanks to vapors2k for the billet-tiful goods btw
