Manual Transmission Oil Weight?
Old Jun 16, 2015 | 02:33 AM
Vague's Avatar
Default Manual Transmission Oil Weight?
Sup Honda fam I have a 97 Civic DX Non LS Trans and I can't seem to find a straight answer about which weight of oil I should use for my tranny, right now I'm using Conventional 5W20 not sure if this is to thin or not but I wanted to get a little more insight from you guys what do you all think?
Old Jun 16, 2015 | 03:39 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Manual Transmission Oil Weight?
Assuming you're talking about an MT, you should be using Honda MTF.
Old Jun 16, 2015 | 03:54 AM
Vague's Avatar
Is that better then what I'm using? and how much does a quart of that cost?
Old Jun 16, 2015 | 04:10 AM
egsleepercivic's Avatar
Before honda had MTF they use to specify 10w30 iirc, otherwise use honda MTF, its about $8 a quart at the dealer by me
Old Jun 16, 2015 | 04:15 AM
Bently_Coop's Avatar
Steve at Heart
Honda MTF, had to many transmissions go out with 10w30
Old Jun 16, 2015 | 04:45 AM
hondamark35's Avatar
old spec MTF was about equivalent in viscosity to 10w30 engine oil. in transmission oil numbers 10w30 is most similar to 75w90. see below.
new spec is more like the 5w20 you're using now. I've yet to see regular, off-the-shelf, non-track spec transmission oil that thin. go with the MTF from Honda. you can find deals ordering it online as some dealers tend to over charge for it.
Old Jun 16, 2015 | 10:43 AM
NotARaCist's Avatar
Honda Fluids - Bernardi Parts
My go-to guys for OEM fluids, lubes, sealants, and all those other fun chemicals. Except HondaLok. I get that for free from the local dealership every time I get something.
Old Jun 16, 2015 | 12:15 PM
Former User's Avatar
I do the same, but Majestic also ships fluids now too. Go with whoever has best price.
Old Aug 12, 2015 | 06:03 PM
jay0504's Avatar
Honda mtf
Old Aug 13, 2015 | 03:42 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Found cases of 12 Honda MTF quarts for $88 shipped on eBay. Or on Amazon, they vary from $8-$9ish including shipping. You need 3 quarts (~2.3 qts) . Problem with Bernardi is the shipping rates. If you have a large order, you can absorb the shipping. But for small stuff, its a bit pricey....especially for fluids since they upcharge the shipping on that.
Old Aug 13, 2015 | 04:00 AM
rick_rabies's Avatar
I'm not Rick!
i have always used mobile 1 10w30. never had a problem. even in higher hp abused trans.
Old Aug 13, 2015 | 05:34 AM
B serious's Avatar
The main *tangible* advantage to MTF is cold weather shift feel. Beyond that, likely longer synchronizer life, etc.
M1 is like $7-8 per quart. Honda MTF is $8-9 per quart at a local dealer. Not much difference in cost. Dealers always have it in stock. So as long as you have a local dealer, the availability is the same for either as well.
I'm sure you're fine with 10W30 and you may not ever see an actual problem. MTF does offer advantages, though.
Torco MTF is another good one. Amazon has them for $10/qt. It improved the shifting feel on my S2000 and made the trans a bit quieter. It also doesn't get that notchy shift feel after 2-3 track days like the Honda MTF. Although, Honda MTF still has better cold weather shift feel. Since this car sees almost no cold weather use...Its not really a factor.
I use Honda MTF in my TSX daily driver at about a 35-40k mile interval. Shifts like silk even in the crazy silly Chicago winter.
Old Aug 14, 2015 | 05:03 AM
asinclado's Avatar
I use penzoil syncromesh with good results. Anyone has an expert opinion about it?
Old Aug 14, 2015 | 05:52 AM
I'm not Rick!
aquafina doesnt show around here much anymore, but he is a tranny guru. he knows the size of teeth to the types of metal used to the capatability of other parts to make a hybrid trans etc. he coudl give a good answer
Old Aug 14, 2015 | 06:34 AM
B serious's Avatar
He's a knowledgeable dude for sure. Apparently, there is a way to "tag" people on HT that would alert them/link them to the thread.
Torco MTF is usually his recommendation over Honda MTF.
Old Aug 14, 2015 | 11:18 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I was just going to say this. Everytime I've seen him (@Aquafina) recommend fluid for our manual trannies it's always Torco MTF over all else or Torco RTF if you are abusing and can spend the extra.
And if I recall, he also said conventional 10w30 over the latest version of Honda MTF but I might be remembering incorrectly there. I do know he said avoid synthetic 10w30 like the plague.
Old Aug 14, 2015 | 11:20 AM
NotARaCist's Avatar
So glad some Freshman bumped this thread with nothing to add, just to get his post count up, and y'all ran with it, continuing to add nothing new.
Old Aug 14, 2015 | 11:24 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
toe may toe - toe mah toe
poe tay toe - poe tah toe
Or are you upset that there are those who think other fluids are better than your holy grail Honda MTF?
Old Aug 14, 2015 | 11:29 AM
I'm not Rick!
Old Aug 14, 2015 | 11:54 AM
NotARaCist's Avatar
Nope. If you check my build thread, you'll actually see that I'm using Torco MTF for a stock, basic, normal DD, Honda MTF all the way. It's affordable, and it's reliable. For aggressive driving, Torco MTF, easy. For track/real performance use, Torco RTF. For the average user, though, there's no reason to waste the money on Torco when Honda MTF does the job just fine.
Old Aug 14, 2015 | 12:01 PM
B serious's Avatar
Torco MTF is $1-3 more than Honda MTF per quart. Its like $9-10 on amazon.
#outdatedinformation
Old Aug 14, 2015 | 12:42 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Makes perfect sense.
Old Aug 16, 2015 | 08:47 PM
Aquafina's Avatar
Except Honda MTF doesn't do the job just as well. It does it worse. If you're cheap, use 10W-30 instead of Honda MTF.
Old Aug 16, 2015 | 09:23 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Glad to see my memory does still work sometimes.
Old Aug 17, 2015 | 12:18 PM
24TEN's Avatar
PHANTOM MENACE
I was actually wondering about my memory as well, I read through this thread a few weeks ago and was surprised at how many people were saying to use Honda MTF when in my head I was thinking that for older transmissions (specifically before Honda changed the MTF formula) it was recommended to use regular 10W-30 motor oil.
