NJ F/s K Series Ek Hatch 5 Lug Recaro R Crew Lsd Complete or Shell
Finally Looking to get rid of my ek hatch. owned it for about 10 years now
Only Selling to expand my business else i would love to keep it around
Depending on how someone wants to buy it im willing to sell it as a complete car or will sell the shell than the motor etc
I Really dont have time to part out the entire car so i can sell the rolling shell with basically everything excluding no power train items (motor/trans/exh/ etc)
Price can be adjusted depending what you want the car with. any serious buyer can be discussed into further detail
Garage kept
Body 8/10
Interior 8/10
Car is 19 Years old
Exterior
96 Hatch w/ 2000 front
Si Front Lip
Oem Si grille
Oem Ctr Mirrors
Type r rear lip
Carbon Duckbill
Interior
Red Recaros Or Black & Red Stitch Your Choice
s2000 Steering wheel
Type R Back Seats
Sk2 Shift ****
Oil Pressure Gauge
Si Tweeters
Power Doors
Type R Arm Rest
Broadway Mirror
Oem Ctr Sun Visors
Si Cluster
C Pillar bar
Suspension
Jdm 36mm Itr Setup
Extended Arp Studs
Stainless Steel F&R Brake lines
Omni Front Camber Kit
Rear Camber Kit
D2 Suspension like new
Polished Asr Bar
Omni Old School Lcas with the circles
Hawk Pads
Dba Slotted Rotors
K Tuned Traction Bar
Blox Lug Nuts
Eg Subframe Setup
Manual Rack
Car Is Forsale on Champ White Itr Wheels Freshly Powder Coated
New Tires, No Chips or Rash at all
Motor
K24/20 Basically All Oem Parts
Arp Head Studs
Type S Oil Pump Setup
Steel oil pan
Tsx Exh Cam
New Tensioner
New Chain Guides
Hasport Mounts
Golden Eagle FR
SS Black Fuel lines
Aeromotive FPR
Blue Print Rbc
Sk2 70mm Tb
Karcepts Adapter
Hondata Gasket
Type R Flywheel
Exedy Stage 2 Clutch (600miles)
Hybrid Racing Interior Harness
Half Rad
Hondata K Pro
Exhaust
Rcrew Header
3in Thermal Turbo Back
3in Vband Setup/Flex Pipe
Transmission
Rsx Type S 04
4.4 Final Drive
Oem Itr Lsd
New Oem Gears
Type s 36mm Axles
Oem Shifter Box/Cables
Literally ZERO Grinds on Transmission
Everything is Fresh
Car makes extremely good #s for a stock oem build
Over 240+hp 190+tq healthy swap no leaks or smoke at all
Te37 / Regamasters / Polished Jdm Itr Wheels /5 Lug Bogart Slicks + Skinnies will be forsale once car is gone
located central nj
please dont waste my time
like i said will sell the complete rolling shell for a certain price depending what you want on it.
can take off certain items to make the price work for you
Asking 12000obo for complete car on itr wheels
Rolling Shell without engine/powertrain components 6000obo
you would need motor/trans,kpro. fuel setup. header/exh everything else would stay listed above
908 two1seven 9653
please no negative comments. Thanks
Garage kept
Body 8/10
Interior 8/10
Car is 19 Years old
Exterior
Si Front Lip
Oem Si grille
Oem Ctr Mirrors
Type r rear lip
Carbon Duckbill
Interior
Type R Back Seats
Sk2 Shift ****
Oil Pressure Gauge
Si Tweeters
Power Doors
Type R Arm Rest
Broadway Mirror
Oem Ctr Sun Visors
Si Cluster
C Pillar bar
Suspension
Jdm 36mm Itr Setup
Extended Arp Studs
Rear Camber Kit
Polished Asr Bar
Hawk Pads
Dba Slotted Rotors
Blox Lug Nuts
Eg Subframe Setup
Manual Rack
Motor
Arp Head Studs
Steel oil pan
Tsx Exh Cam
New Tensioner
New Chain Guides
Hasport Mounts
Golden Eagle FR
SS Black Fuel lines
Aeromotive FPR
Blue Print Rbc
Sk2 70mm Tb
Karcepts Adapter
Hondata Gasket
Type R Flywheel
Half Rad
Hondata K Pro
Exhaust
Rcrew Header
Transmission
Rsx Type S 04
4.4 Final Drive
Oem Itr Lsd
New Oem Gears
Type s 36mm Axles
Everything is Fresh
located central nj
908 two1seven 9653
Jdmdctek
Mid-Atlantic (Sales)
Dec 14, 2015 04:44 PM
Jdmdctek
Northeast (Sales)
Jul 1, 2015 07:09 AM
SLUGFEST
Nov 20, 2013 05:00 PM
