AEM EMS coil dwell factor
Old Jun 15, 2015 | 08:24 PM
Dom_GsR's Avatar
Icon2 AEM EMS coil dwell factor
Hi,
I have a question regarding the coil dwell factor. What is the best settings? I have ''upgraded'' ignition part but still get boost cut/missfire above 9-10 psi when I try to gap the plugs larger than .18... is this normal or I should be able to get wider gap? The car is a GT30R B18c1 that is boosted since 2007.
Stock ignitor bypass/removed
MSD Digital 6AL Ignition Control
MSD HVC-2 Coil, 6 Series Ignitions
My current dwell factor is 30
dwell max is 4.50
dwell min is 0.05
i'm also curious about the dwell vs batt volts table and dwell vs rpm table.... what do you guys use?
Thanks a lot for your precious help!
Old Jun 16, 2015 | 09:48 AM
Rtype16's Avatar
Default Re: AEM EMS coil dwell factor
The only problem you would run into if your dwell was set too high and it is running into each other on the high RPM. You having a MSD installed pretty much doesnt matter what the dwell is as the MSD is controlling all of this. Is this a Series 1 or Series 2 EMS. What do you have selected in the Coil Dwell Wizard?
Old Jun 16, 2015 | 11:49 AM
Dom_GsR's Avatar
Thanks for the reply!
I have a series 1 AEM and the coil dwell wizard is set to All CDI Systems (Except Ford TFI) is this ok?
Old Jun 17, 2015 | 11:59 AM
accorse07's Avatar
You have selected the recommended default setting which is 2ms. It is perfectly fine to have this selected.
Old Jun 18, 2015 | 07:26 PM
VegasInvasion's Avatar
I'm Huge In Japan
alternatively, cam timing can affect dwell, which can fluctuate with adjustable gears and/or a shaved head.
b18prl
Sep 13, 2004 10:44 PM
Hybrid
Oct 22, 2002 02:13 PM
EleanoR
Jun 26, 2001 03:17 PM
