what engine harness do i have, jdm or usdm?
i bought a b16a2 a couple weeks ago and the guy handed me the harness as i finished loading the motor. i need to know if it's a jdm or usdm harness. I've tried searching for the answer but all i found was ''don't bother with a jdm harness''. how do i tell the difference between the two?
Is there a good reason you haven't posted a bunch of informative pictures so that members don't have to imagine what you might be seeing?
Why not call the guy on the phone or text him for the answer?
Are you able to answer my question?
Here's a question for you. What is hidden directly behind the sun right at this moment?
It's pretty easy to figure out, if you use a little bit of logical thinking, OP. Is the distributor plug close to the ECU plugs, or as far away as possible? You could have stopped and thought about it, and figured that out yourself in the time it took you to create this thread, and act like a ******** towards a respected member of the forum.
i wouldn't trust his word since he was wrong about so many other aspects of the motor.
the answer to your question is, endless wonders.
eddiecut
Aug 17, 2003 07:39 PM
