Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Low Idle and Misfire
Old Jun 15, 2015 | 11:26 AM
aaronjvance's Avatar
Default Low Idle and Misfire
I have a 2005 Honda Civic which is idling low (500-600 RPM) and will intermittently drop to about 200 RMPs for a second. While at idle it will continually cycle through this process. Also if I drive the car, it will misfire once it gets between 2000 - 3000 RPMs. I had this issue about 6 - 8 months ago and replaced the Lower Crank Sensor, which fixed the problem.
Since I am experiencing the exact same symptoms, I am thinking that I may have gotten a bad sensor, but wanted to see if there is anything else I should check.
Any ideas or suggestions?
type r em1
Jul 4, 2019 11:46 AM
Nisif
Nov 26, 2011 07:22 PM
Mazdaholic
Jul 15, 2010 09:58 PM
B17DA-SON
Feb 5, 2010 09:23 PM
go2sleep
Jun 15, 2006 08:54 PM
