coolant leak thermostat assembly/housing bolt
Old Jun 14, 2015 | 09:53 AM
Swansen's Avatar
Default coolant leak thermostat assembly/housing bolt
the long bold that screws into the head that hold the whole assembly in place, this bolt is partially exposed running through the body of the housing. seems there is coolant leaking from here? however, unless there is some crazy corrosion coolant shouldn't be coming from that bolt right?
i need to take the whole thing apart and look at it, but, just looking for ideas. thanks
also, the bolt i'm talking about is the one in discussion in this thread(ie broken one) https://honda-tech.com/honda-civic-d...-pics-3035186/
Old Jun 14, 2015 | 11:10 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: coolant leak thermostat assembly/housing bolt
If you are leaking from that bolt that is broken in the thread you linked, I would think your thermostat housing cracked.
If you had said the bolts holding the housing halves together then I would say you need a new thermostat and seal.
Old Jun 15, 2015 | 03:26 PM
Former User's Avatar
All tech threads require car information - See Rules sticky.
Root of all Evil
Oct 29, 2011 09:54 AM
wtsapexipowerfc
Aug 20, 2011 01:54 PM
marty17
Dec 13, 2009 06:55 PM
OogalyDoogaly
Honda Motorcycles
Feb 4, 2008 05:31 AM
SPEED123
Feb 15, 2003 07:26 PM
