Replaced Radiator. Now AC Doesn't Work.
Old Jun 14, 2015 | 12:56 AM
JurassicPark's Avatar
Default Replaced Radiator. Now AC Doesn't Work.
1999 Accord LX 2.3 4cyl
I'm a novice repairman, but I decided to try replacing a bad radiator myself. Took most of the day, but it worked! Car no longer overheats.
However, now my AC does not work.
When I press the AC button, I can hear the condenser fan kick on, but no cold air. I don't think the compressor is turning on.
I noticed that the AC system is right up next to the radiator. Maybe I bumped something when I was replacing the radiator and caused a leak? Or maybe it's something electrical?
Old Jun 14, 2015 | 03:18 AM
tim73's Avatar
Default Re: Replaced Radiator. Now AC Doesn't Work.
You probably damaged or left off the wire to the compressor and or compressor relay.
Old Jun 14, 2015 | 04:05 AM
Lost Again's Avatar
Compressor relay is in the underhood fuse box
Old Jun 14, 2015 | 10:14 AM
Double-checked the electrical connection to the compressor and turns out it wasn't fully seated. AC works now. Thank you.
Only issue remaining is that the radiator fan doesn't seem to want to come on. It will turn on along with the condenser fan when I turn the AC. However, when I was refilling the coolant, the service manual told me to idle the car until the radiator fan came on twice. It never did. Is this a problem?
Old Jun 14, 2015 | 10:57 AM
cafrog's Avatar
How long did you run the car for?
Old Jun 14, 2015 | 11:39 AM
I ran it at least 5 min.
Old Jun 14, 2015 | 01:14 PM
holmesnmanny's Avatar
The car has to fully warm up before itll come on.
Old Jun 14, 2015 | 04:12 PM
cafrog's Avatar
Depending on outside temp, it can take awhile. With a cold start, I usually run my car for 15-20 minutes before the fan kicks on.
Old Jun 14, 2015 | 04:16 PM
rockycat's Avatar
Watch the temp gauge and don't go past 1/2 way.
Old Jun 15, 2015 | 08:50 AM
Didn't realize it would take that long for the fans to come on. I'll watch the temps, but it sounds like everything is right. Thanks guys.
cn_bb
Aug 9, 2012 11:00 AM
thakidd
Jul 1, 2008 07:29 AM
tthomass
Feb 2, 2005 07:18 PM
