99 civic hx speedo not working
Got a 99 civic hx speedo not working. No CEL, swapped gauges with known working unit, still same problem. Fuse 15 not blown. Any other options I can try? Any help would be awesome.
If u swap the cluster u made sure all components where connected properly?
double check fuse with a meter make sure their right voltage coming in and out ?
Did u check vss sensor?
Yes, CEL is functioning properly. I'm getting a multimeter thursday. How should I go about testing? Turn key to on and test or do I have to lift the front up? And what amps would I be looking for to ensure it's getting proper ampage?
Ok sorry it's been so long. Any who finally got the speedo figured out. Works good, I had to run a wire from my blue/white signal wire to the b11 pin on the back of the cluster. I must of cut it or something lol but all works. Thanks for all the help.
Mzmonika
Sep 5, 2016 07:58 AM
ONEhaque
Nov 4, 2008 06:31 PM
