Can someone answer this for me?
Old Jun 12, 2015 | 07:49 PM
Dc4Colin's Avatar
Default Can someone answer this for me?
Can i do a ls/vtec swap on my 99 integra rs auto? Also swap the ecu and put a p72 gsr auto ecu in as well. Would it work?
Old Jun 12, 2015 | 08:17 PM
1996midori's Avatar
Default Re: Can someone answer this for me?
Well considering you already have the "ls" (b18b1) just swap a gsr head onto your current block and run wires to a gsr ecu for the VTEC pressure switch and solenoid.
Old Jun 13, 2015 | 04:52 AM
Dc4Colin's Avatar
Ok. My cars automatic. So this will still work? And by no means am i lookkng for greatly increased HP just something ill notice
Old Jun 13, 2015 | 05:14 AM
Dc4Colin's Avatar
Old Jun 13, 2015 | 03:34 PM
1996midori's Avatar
Wait. Sorry I hadn't realized there is no auto gsr. Thus no ecu to control the shift points with the throttle position.
Old Jun 13, 2015 | 06:36 PM
tony_2018's Avatar
Fish Twig
There is such a thing as an auto gsr.
Old Jun 13, 2015 | 08:23 PM
kingkau's Avatar
37820-P72-902 B18C GSR Automatic Ecu
Old Jun 14, 2015 | 02:56 AM
cvcrcr99's Avatar
OP, if you are capable of learning/driving manual, swap the trans. It'll be more fun to drive and give you more possibilities down the road.
Don't mod Auto Hondas for power, the trans will quickly fail
Old Jun 16, 2015 | 06:01 PM
safedriver's Avatar
The secret to learning to drive a stick shift...learn to control the gas pedal.
Get a feel for revving the engine between 1000 and 2500 rpm.
Later, as you let out the clutch, focus on the gas pedal and don't let the engine speed drop, below 1500 rpm.
Old Jun 18, 2015 | 02:30 AM
PHAT-INTEGRA's Avatar
There is no such thing as a USDM GSR Auto. It's a JDM SIR-G Auto.
JDM P72 AT ECU (Dual butterflys valves) or JDM P30 AT ECU (Single butterflys valve). will control the shift points. There is allot more just to slap a head on and wired. There are allot of other things that need to be done if you want it reliable.
I have a built GS/VTEC AT. Search the forums and other website it's been covered many time.
GSRBrent
Nov 18, 2007 12:54 AM
mrdeadman
Mar 5, 2006 07:41 PM
dmolisee
Oct 3, 2005 05:09 PM
shotty527
Oct 16, 2002 05:47 PM
