Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2012 Accord SE Changing a Multi Switch Function
Old Jun 11, 2015 | 07:22 PM
devilbryan1's Avatar
Default 2012 Accord SE Changing a Multi Switch Function
Does anyone has step by step instruction on how to remove and change the multi switch function for headlights, turn signal, etc. My passenger highbeam would stay on while the engine is off. As of now I took off the bulbs and I'm driving with no high beam.
Old Jun 13, 2015 | 01:00 AM
lazlong's Avatar
Default Re: 2012 Accord SE Changing a Multi Switch Function
You need to do an input test to be sure it's the multi-function switch. Should be able to get a service manual on disc or download for super cheap on eBay. Or you can get a paper copy for around $50 here: Honda 2008-2012 Accord L4 Service Manual (KA) - Helm Incorporated At the very least you need to test the high-beam relay to be sure it's not stuck.
I don't know your specific model but, they're all similar and very easy:
1. Adjust the steering column all the way up
2. Remove the 2-3 phillips head screws holding the bottom plastic cover to the column
3. Adjust the column down
4. Pop the top and bottom plastic covers apart and remove
5. Disconnect the multi-function switch electrical connector
6. Remove the 2 phillips head screws holding the switch to the cloumn
Old Jun 13, 2015 | 10:57 PM
it's a 2012 Honda Accord SE (Special Edition). I was thinking it could be the highbeam stuck relay but I been having trouble locating it. There's 3 fuses boxes: under the hood, driver, and passenger side. Some folks said its under the hood but I can't tell which is it from looking at the manual.
danomatic93
52
Nov 16, 2018 02:53 PM
scottsdale1977
Jul 28, 2014 07:32 AM
ldutton
Jan 25, 2013 02:48 AM
ace260
Jun 27, 2009 06:11 PM
JLefevers
Jan 4, 2008 05:09 PM
