Finally found p0505 solution!
Old Jun 11, 2015 | 11:17 AM
andrewhurson's Avatar
Default Finally found p0505 solution!
For the past 6 months I've been having the p0505 issue where the car would jerk/bounce rpms around 1700 and idle high/hunting. After posting to many sites and troubleshooting, and checking for vac leaks, replacing iacv, adjusting idle etc with nothing working, I finally found the issue. CHECK YOUR AIR ASSIST SOLENOID! If I
Am correct it is designed to allow more air into the engine when cold to help allow the car to reach temp, and when the car reaches roughly 150 degrees it's suppose to shut itself. After testing, mine was staying open all the time! I hope this may be of some help, if you've checked everything else dont forget to check this! My car has been like new ever since. Car is a 1999 civic ex manual.
Old Jun 11, 2015 | 02:42 PM
TysonB's Avatar
Default Re: Finally found p0505 solution!
You simply found the solution to your specific problem. Nice figuring it out though! Must have been frustrating with crappy idle lol.
Old Jun 11, 2015 | 03:00 PM
For sure, just want to give people a heads up of another possible thing causing the annoying problem lol
Old Jun 11, 2015 | 04:33 PM
Former User's Avatar
Originally Posted by andrewhurson
If I Am correct it is designed to allow more air into the engine when cold to help allow the car to reach temp, and when the car reaches roughly 150 degrees it's suppose to shut itself.
Old Jun 11, 2015 | 04:56 PM
NotARaCist's Avatar
I never narc'd on nobody!
Worth mentioning, I believe this solution will only work for 99-00 Civics. I don't think that 92-97 have the AAV.
Old Jun 11, 2015 | 04:57 PM
Only 99-00 Y8s
Ali Tohma
16
Aug 9, 2016 11:22 AM
leonard1818
Nov 23, 2005 12:12 PM
crashtest Sonny
13
Mar 4, 2003 03:49 PM
97AccordLx
Jun 9, 2002 05:44 AM
oem
Mar 21, 2002 04:38 PM
