1992 VX lean burn problem
Old Jun 10, 2015 | 04:31 PM
EGvxhatch's Avatar
Default 1992 VX lean burn problem
Whenever I try to initiate lean burn for anytime longer than a few seconds the check engine light comes on and the car gets out of lean burn. Should I just replace the injectors or is there something else I need to do?
Old Jun 10, 2015 | 07:28 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 1992 VX lean burn problem
You might want to pull the CEL codes. They should be stored now that the CEL has been triggered multiple times.
Old Jun 10, 2015 | 07:50 PM
NotARaCist's Avatar
I never narc'd on nobody!
By "might want to", he means you need to. Drive until the CEL comes on, pull over, and jump the service connector without turning off the car. The CEL will start blinking codes. If you aren't 100% sure what you're looking at, after jumping the service connector, use your phone to make a video of it and post it here so we can help you.
Old Jun 11, 2015 | 04:15 AM
EGvxhatch's Avatar
Ok, I've got the dash disassembled and have the front subframe out of it now. So, I'll have to do that once I get the other stuff fixed.
Old Jun 13, 2015 | 07:33 AM
jlk16188's Avatar
most likely your O2 sensor. Dont get sticker shocked when you see how much a VX sensor costs ($200-400)
ralphyrue
Sep 7, 2016 03:59 PM
LaOXXKIDD
Aug 22, 2009 05:42 AM
1994hondaprelude_dude
Oct 1, 2006 01:51 PM
crxforum
Aug 30, 2004 07:01 AM
