Suspension & Brakes Theory, alignment, spring rates....
94-01 Integra/96-00 Civic ex front sub frame compatible?
Old Jun 8, 2015 | 06:22 PM
Ghunt521's Avatar
Default 94-01 Integra/96-00 Civic ex front sub frame compatible?
As topic says, will a 94-01 Integra front subframe bolt up to a 96-00 civic ex? Thx
Old Jun 8, 2015 | 07:31 PM
Hites's Avatar
Default Re: 94-01 Integra/96-00 Civic ex front sub frame compatible?
Remind me on Friday, and I'll check.
Old Jun 8, 2015 | 07:34 PM
Ghunt521's Avatar
okay will do,like to get the answer sooner lol
Old Jun 9, 2015 | 02:50 PM
FrostyEG's Avatar
I would also like to know if either of these (94-01 teg and 96-00 civic) will bolt on to the 92-95 civic...
Old Jun 10, 2015 | 05:13 AM
phunhaus's Avatar
Yes, they all bolt up BUT there are front LCA differences to consider.
What exactly are you tring to do?
Old Jun 14, 2015 | 05:18 PM
Honda Type R's Avatar
I've installed a DC subframe in an EK before. You're going to need the DC bolts (all of them if I remember right), DC rack and pinion, DC or EG rear T bracket depending if you have a B or D series, DC LCA's, and a DC front sway bar. There are these 2 cast iron spacers bolted to the subframe. I don't remember if they need to stay or be removed. Test fit it without the rear mount or control arms so you can see if they need to come off. I don't *think* they need to come off but I may be wrong. You can also use all EG parts since they're the same as DC with the exception of manual steering. If you use a power steering subframe you can use an EG manual rack but you need to make a spacer on the bushing that wraps around the housing. If you use a manual steering subframe, you need a manual steering rack. I'm fairly certain on this part but I may be wrong since I've only ever dealt with power steering stuff.
The EK subframe is a heavy turd compared to the DC subframe. The EK subframe with a manual rack, LCA's, and front sway bar weighed a good bit more than the DC subframe with a power rack, a larger sway bar, and LCA's. I dropped it as a whole and installed it as a whole. Luckily I had a whole Integra to pick all the parts from so all I had to do was grab parts and install them. That's why some stuff is a little fuzzy. Also, it's a 1 man job but 2 people makes it a little easier.
Old Jun 18, 2015 | 03:10 PM
FrostyEG's Avatar
I have a 93 VX and I want to install a front sway bar. I picked up the front crossmember with LCA's, sway bar and power rack from a 96 integra. I plan to do the DC to EK pinion swap for a quicker LTL and also convert the rack to manual.
Old Jun 18, 2015 | 03:34 PM
If you put an EK pinion in the DC rack it'll slow it down, not speed it up. I just converted my rack (DB8) to manual and welded up the pinion. I did the true manual rack conversion. Oddly enough I followed a Miata write up lol Make sure you drill out the stake mark on the end cap of the rack (the one you unscrew).
Caoboy
Suspension & Brakes
16
Feb 20, 2015 09:05 PM
junk95civ
Feb 16, 2010 01:12 PM
redDAinteg
Oct 22, 2009 04:49 PM
Log4n
Dec 11, 2006 08:42 PM
Atheist
Oct 14, 2005 03:39 PM
