Fuel tank braided line?
Old Jun 8, 2015 | 01:26 PM
carlos8's Avatar
Default Fuel tank braided line?
From the beginning, I knew it my car has the feed line hacked and fixed with rubber fuel line. A few days ago the line blow it. Now I'm making braided from tank to filter -6an
I have all the fittings and lines inclusive a new AEM 50-100 320lph.
My question is, Anybody has put the 5/16 to -6an fitting in the pump hanger? I'm thinking on cut it to make it a little short and put the fitting.
https://honda-tech.com/attachment.ph...1&d=1433798709
If somebody have doing this can please post a photo.
Old Jun 8, 2015 | 01:48 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Fuel tank braided line?
Just remove the plastic lock and keep the barb for sealing purposes. I have done this a few times actually. If you need to, cut down the pipe some but before the barb. Make sure you use 2 or 3 hose clamps in alternating directions though.
It has been a while, but I do believe they also sell adapters to go to NPT and Barb from that quick connect fitting to do it the right way. OR you could always use a bulkhead fitting or even weld a fitting. Many, many possibilities.
Old Jun 8, 2015 | 02:11 PM
carlos8's Avatar
thanks, that is a good advice. I'll do it tomorrow...
Old Jun 8, 2015 | 06:55 PM
wantboost's Avatar
Who is Mr Robot?
they sell adapters to fit those style fittings, OEM quick release on one side, 6an on the other. no point in cutting it down really, unless there's little room. Although you could gently bend that tube slightly to make room without kinking, crushing, or cracking the pipe
like this
why make things more complicated?
Old Jun 8, 2015 | 07:15 PM
DO IT ON ALL FOURS
Second paragraph of my post.
boarding2008
10
Aug 1, 2010 09:01 AM
dmotoguy
Mar 2, 2008 10:27 AM
1QwIkEf
Jan 28, 2006 05:05 PM
endlesswinterco
Nov 2, 2005 08:47 PM
IMSTOCK
Aug 23, 2004 08:46 PM
