92cb7 over heating
Old Jun 7, 2015 | 10:02 PM
laloquera916's Avatar
Default 92cb7 over heating
Im over heating, no leaks, new water pump, t-stat, rad cap, both fans working properly. It starts and holds normal temp, drive up to a red light and the needle shoots to red line. The over flow reservoir boil out coolant and a lot of steam. No water in the oil and no oil in the water.
That's were I am at.
Thanks
Old Jun 9, 2015 | 04:30 PM
Lost Again's Avatar
Default Re: 92cb7 over heating
Don't take this wrong but the list is long.......
OE or aftermarket t-stat?
Are the fans spinning the right direction?
Are you 100% sure you bled the coolant system properly...if you are how did you do it?
10psiLsEf2
Nov 2, 2011 07:20 PM
fukenricen
Nov 8, 2010 04:39 PM
Smily0087
Feb 16, 2010 11:42 AM
Quik89Si
Jan 3, 2005 07:06 PM
forksports
Jan 17, 2004 09:32 AM
