2000 Honda Civic Idle problem
Old Jun 7, 2015 | 04:39 PM
Tdelgado03's Avatar
Default 2000 Honda Civic Idle problem
Hey Everyone! I'm in need to ideas and help.
I have a 2000 Honda Civic dx with a d16y7 motor. The car only has intake, and full exhaust. I was driving it the other day perfectly fine, and went to put gas. At the gas station I put 93 octane. Didnt think it through since it doesn't need it. But I filled up the tank from Empty. After that the car has been acting up. Literally right after I started it. The idle flunctiates when cold, but after it warms up it idles around 1500 RPM. Also the car is stuttering from 1600-2k Rpm. I've never had this problem and have no idea what it may be. I checked the TPS sensor and it is receiving the voltage necessary. Can it be the fuel? Thank you in advanced for the help. Really need to get this fixed.
Old Jun 7, 2015 | 04:47 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 2000 Honda Civic Idle problem
Is the CEL on? Does it work?
Remove, clean, and reinstall your IACV. You can find a how-to in the DIY sticky. Make sure to properly bleed your coolant afterwards.
Old Jun 9, 2015 | 04:30 AM
Tdelgado03's Avatar
I will try to clean the IACV later on today. Hopefully that works. There are no codes on. Can It be the gas I put?
Thanks
SOL4life
Feb 12, 2025 08:43 PM
Snags73
Classic Hondas
Mar 28, 2017 06:38 PM
blue2006civic
Honda Civic (2006 - 2015)
Jun 17, 2015 06:13 PM
quick gixxer
Jan 11, 2004 09:41 PM
quik1
Dec 19, 2003 03:32 PM
