Fuel Relay?
Old Jun 7, 2015 | 12:38 PM
lsdisco's Avatar
Default Fuel Relay?
So, I've been working the last several weekends swapping an obd1 b16 in to my 88 crx hf. I was so excited going in to this morning because I knew today would be the day I start it for the first time. The problem is, when I turn the key on the fuel relay opens and closes at an intense rate. At first I thought something was vibrating real loud.
The motor turns over but doesn't start.
I believe it is giving me a code 4. Possible I wired it incorrectly. I only tied in one wire and left the other one hanging. (?)
This did not occur before swap.
I am using a p30 ecu.
I do not believe any of the wiring I did My self would have caused this. Any help or ideas would be greatly appreciated.
Old Jun 8, 2015 | 04:21 AM
ryanplayjoint's Avatar
Default Re: Fuel Relay?
Ground wire at thermostat housing.
Old Jun 12, 2015 | 01:16 AM
lsdisco's Avatar
It was 100% ground wire at thermostat housing. Still have code 4 though. Tonight i go through my cheap distributor harness, wire by wire. Thank you.
maltman111
Apr 27, 2013 01:39 PM
Trex88dx
Jul 12, 2012 08:15 PM
turbox
Feb 15, 2009 05:58 AM
Christianva
Audio / Security / Video
Aug 19, 2008 06:41 AM
Rexxer
11
Jul 9, 2004 11:21 PM
