crank no start issue?- damaged distributor wire (solved)
Old Jun 5, 2015 | 08:36 PM
SVOHK's Avatar
Default crank no start issue?- damaged distributor wire (solved)
2000 Honda Civic
-No check engine light
-car is getting fuel
-I checked my timing (TDC) its fine
-car has spark
-Replaced: Rotor,Cap,Igniter and Coil.
Long story short
Car shut off while driving and realized the car had no spark.
The problem was a bad igniter and now i have spark. but it still just cranks and doesn't start.
While I was messing around with the distributor trying to find the problem I damaged the Blk/Yel wire inside the distributor.
Would the damaged Blk/Yel wire cause the car from not starting?
Old Jun 6, 2015 | 06:24 AM
Former User's Avatar
Default re: crank no start issue?- damaged distributor wire (solved)
Repair the wire and check whether the spark plug wires are installed in an incorrect firing order.
Old Jun 6, 2015 | 10:25 AM
SVOHK's Avatar
Will do.
Spark plug wires are in correct order.
I forgot to mention that it seems my fuel injectors are not spraying when i crank it. I removed all spark plugs and all the cylinders are completely dry as well as the plugs. (Fuel rail has gas)
I know it has to be something electrical. Main Relay is good so i know that's not the problem.
I have not tested the "TDC/CYP AND CKP" sensor inside the distributor and i believe that might be the problem.
This sensor affects the injection correct?
Old Jun 6, 2015 | 10:49 AM
Have you checked for spark?
CKP sensor is required for both spark and fuel (injectors). CEL codes?
Injector clips get voltage?
Old Jun 18, 2015 | 08:37 PM
SVOHK's Avatar
Fixed!
the problem was the cylinders were so dried up (from so much cranking and gas i believe? ) it had low compression. I poured in a small amount of oil in each cylinder and cranked it and it started right up.
Old Jun 18, 2015 | 08:46 PM
SVOHK's Avatar
Thanks for the help ron
Jaynik
46
Dec 4, 2013 05:29 PM
Tommy818
28
Oct 22, 2012 10:00 AM
yzhang
Jun 21, 2009 11:13 AM
matt69vdub
Jul 23, 2007 08:35 AM
btrim23
Apr 24, 2004 04:52 PM
