Noise when applying brakes
So I been getting this weird type of squeak and squeal noise coming from the front passenger side, cars a 93 sol with the d15. it's only when applying even the slightest amount of brakes. I have replaced axles, tie rods, wheel bearing, removed the dust cover, and got a alignment and they said there is nothing wrong the brakes have plenty life left 6mm pads and rotors looked good.
So I'm like WTF, and the noise is very loud, it almost sounds like my UCA's are rubbing but I just jacked it up and greased the squealer pin and where I think the UCA's are rubbing and the sound is less apparent but I still hear it more of under light braking.
What could this be? Thanks guys.
So should I look into new pads?
I did not get to look at them, couldn't break the caliper bolt loose.
But I did notice on the bottom of the caliper there is something that says "L" and that part is on the right side of the car.
No, have not did a brake job on it due to exceptional pad life and my rotor is still in the recommended thickness. But if all fails I'll be replacing them.
Okay guys so update on this I replaced the rotors and pads in the front, after a few days the noise came right back.
I just noticed there is a good amount of drag in the rear right wheel with the parking brake released. Problem is the parking brake is adjusted accordingly, 6-9 clicks. So how do I go about adjusting the the drum to get less drag? When I have the ebrake fully engaged and I push on my car I can hear the rear drum make a knocking noise. I did take it to a shop to have the rear brake shoes done last month.
And I noticed the asshat only replaced the rear right drum which is the one with the drag and making noise.
Please if somebody could just tell me how to adjust it I'd be so thankful. Or should I take it back to the shop that did it?
Purchase the following-links to generic kits follow purchase whatever brand you please just ensure it has the parts:
Wearever Drum Hold Down Parts and Springs 17351: Advance Auto Parts
Wearever Drum Brake Self-Adjuster Repair Kit 2701: Advance Auto Parts
Jack up car safely-ensure parking brake is RELEASED.
Remove the wheel and drum in question.
Clean thoroughly with brake parts cleaner and dry with a clean shop rag.
Use a flat head screwdriver to adjust the parking brake self-adjuster so that the shoes go "in" (away from the outer surface of the drum).
Replace any worn, damaged, broken or bent parts with new ones from the 2 kits you purchased.
Re-assembly is the reverse of removal.
How-To Video:
dis-assembly:
me_brewsta
Oct 27, 2016 05:55 PM
