#teambrickner Wife's "Surprise" 90' Civic Si Track Vehicle Build
Old Jun 4, 2015 | 04:40 AM
4NLINE UNLIMITED's Avatar
Default #teambrickner Wife's "Surprise" 90' Civic Si Track Vehicle Build
Decide to get back on the Forums instead of addicting Book of the Faces.
http://www.facebook.com/bricknerftwhttp://www.instagram.com/bricknerftw
Picture Album on Facebook below.
https://www.facebook.com/BricknerFTW/media_set?set=a.10152955899462741.565032740&type=3
Modifications List
Brakes/Chassis/Suspension:
Motul RBF 600 Factory Line Fluid
J's Racing Brake Line System
*Spoon Sports 4-Pot Twin Block Calipers
*Spoon Sports Front Chassis Tower Brace
*Spoon Sports Rear Chassis Brace
*Spoon Sports Rigid Collar Kit
96' - 97' ITR 4x114.3 Conversion
ARP Extend'd Studs
x3 Novustech Wheels Spacers Hub Centric
Center Bore 64.1MM in 10MM/15MM/20MM
Hardrace Adjustable Front UCAs
Cusco Front Lower Tie Brace
Neuspeed Rear Lower Tie Brace
PIC Select Full Body Coilovers ITR LCA
SPC Spherical Rear Toe Adjusters
Engine/Transmission:
94' Si D16Z6 Engine
Motul 300v Power Racing 5W30 Oil
Unorthodox Single Belt Crank Pulley
Hasport Billet Hydraulic Engine/Trans Mounts
Edelbrock Pro-Flo Competition Header 6725
Custom Test Pipe made by Scott Steensen​
J's Racing Titanium 60RS Exhaust
J's Racing Magnetic Engine/Transmission Drain Plugs
J's Racing Carbon Tsuchinoko Intake System
J's Racing Engine Torque Damper
*Spoon Sports Engine Torque Damper Mount
*Spoon Sports Magnetic Engine/Transmission Plugs
*Spoon Sports Modified Hi-Tension Plug Wires
*Spoon Sports Radiator Hose Kt
*Spoon Sports Thermo Switch
*Spoon Sports Radiator Cap
*Spoon Sports Gen1 Oil Cap
*Spoon Sports Reservoir Covers
*Spoon Sports Heat Barriers (3)
Motul Mocool Coolant System Additive
JDM D15B LSD Hydraulic Transmission
Motul Gear 300 75W90 Oil
Competition Forged Ultra Lightweight 8LB Flywheel
Exedy Stage 1 Clutch Disc & Pressure Plate
Hush Performance​ Cable to Hydraulic Pro-Street Convert Kit
Full Spectrum Power Pulse P2 Lightweight 1.6LB Battery
Full Spectrum Power Pulse P2 Black Battery Bracket
Interior:
USDM Lower "Audio" Console
OEM Honda Single DIN (Radio) Delete Plate
OEM Honda Clock Delete Plate
DTD Honda EF Control Race Panel
Mugen Push Start Button/Switch (Black)
Defi USDM Amber/Red Edition Gauges
K-Tuned B/D Series Adjustable Shifter Assembly
*Spoon Sports Duracon Black or Blue (ICB) Shift ****
*Spoon Sports Gen2 Horn Button
*Spoon Sports Lanyard Key Attachment
*Spoon Sports Steering Wheel Boss (Hub)
_g_121 IG Custom Titanium Steering Wheel Bolts
Mono Monte Carlo 350MM Red Stitch Steering Wheel
Sparco Racing Pedal Covers (Keel/Toe Adjustment)
Bride Zeta II Kevlar Bucket w/ PCI Mount/Rails
Takata Long Version 4 Point Harnesses
AutoPower 6Point Bolt in Roll Cage (Custom Air Brush)
Exterior:
OEM EF-9 SH3 Vtec Center Garnish
EDM Red Integra Integra Type R Emblems
EF-8/9 Custom Cut/Air Duct Passenger Headlight
EF-6/7/8/9 Stanley Clear Corners
EC8 1.6i "ZC" Glass Headlights
VIS Racing OEM Si-R Style Hood (Custom Vent)
VIS Racing ZC Paint Match'd Carbon Hood
J's Racing Type-T Carbon Hood
J's Racing Rear Spoiler
J's Racing/Chargespeed Replica Lip
*Spoon Sports Replica Mirrors
*Spoon Sports Heat Barrier (1)
Wheels/Tires/Lug Nuts:
Project Kics Neo Chrome R40
x6 Desmond/Spoon Sports 15x7 x114.3 +45 Wheels
x8 205/50-15 Falken Azenis RT-615K
x4 96' - 97' 15x6 Integra Type R Wheels
x4 195/50-15 Bridgestone RE-11
Misc/Decals:
Motul Now on Duty Decal
Spoon Sports Logo Mark Decal
Spoon Sports/Type One Mark Decal
J's Racing OG Motorsports Decal
Honda Twincam Feel's Decal Set
Manufacture Count List:
Spoon Sports​ 20 items
J's Racing 7 items
Keep in mind we're 1,200 miles away from her Civic right now. Would of been more Documented but we did the Best we could.
"This Civic was a Surprise Christmas Present for Stephanie. Originally bought from Alex who saved this from the Scrapyard, Platform has been a decent Candidate to work with. Eric, Lil Jake & myself (mostly Lil Jake) knock'd out a Full 96' - 97' Integra Type R Brake/Knuckle/Trailing Arm Conversion along with 1" Integra Brake Cylinder/Booster + Full Body PIC Select Coilovers but couldn't be done w/o the help of Bob for let'n us use his BroPad Shop. w/o the Help from them, this Build & Surprise would not exist. Love you Guys ♥ Really Appreciate what everyone has done. This Album will be a reminder for how Great you Guys are & a Continues update of what you've Guys Accomplished & her New Adventure into the Track Life according to her "Wild Wild West"."
On the to the Pictures.
Few Shots of her Civic wait'n to be Process'd into the Junkyard till my buddy Alex Garber put a Hold on it.
First Purchase. Complete 96' - 97' Integra Type R Conversion + 1" MC w/ Booster. Eric replaced the Front Hub Bearings, Resurfaced the Rotors & install'd Extend'd ARP Studs.
Saved a Set of PIC Selects from an old Integra Type R we had.
Now on to Pictures when we we're able to go back home for Christmas. Special Thanks for Cody for let'n us use his BroPad Shop. Also install'd a Momo Monte Carlo 350MM steering wheel along w/ a Spoon Sports shift ****.
Onto an Alignment by my buddies Lil Jake & Buckley at my old work Superior Honda of Omaha. Specs weren't the Greatest. Still have to order some MOAR Suspension Components in order to Correct the Rear Toe & Front Camber.
& here we are today, sit'n at another friends place wait'n for Body work to start.
More Recent Purchases. Pair of Desmond RegaMaster (SW388) x114.3 +45 15x7, Spoon Sports Front Strut Brace, OEM Honda Radio Delete Plate, Buddy Club Spec Racing Bucket w/ Kirkey Rails, SPC Rear Toe Adjusters, D16Z6 Complete Swap & OBD0 - OBD1 Conversion Harness.
Forgot about this, Pick'd up a ZC Carbon Hood back in Dec for her Civic. Still debating on if I want to use my J's Racing hood on her Civic or not tho.
2 recent Pick ups over the weekend, 4 Point Roll Cage & Takata Harnesses.
Order'n more parts tomorrow along w/ another 2 Sets of Wheels as well.
Went to visit her Civic back in Jan. Buddies S2000 which is now Honda Element Root Beer Metallic.
x6 Falken Azenis RT-615's came in last month Feb.
Custom Passenger Air Duct Si-R Headlight to go w/ my J's Racing Type-T hood on to her Civic along w/ match'n Driver Si-R Headlight & Stanley Clear Corners. Thanks to Jo Alvaro & Robby Biron aka Biron Yo Garage.
Bought a Set of New J's Racing Brake Lines from Carlos EF Heaven & Won Yahoo Japan Used Spoon Clappers Wrd. Just need to get Rotors & Pads then be Ready for install.
Little Care Package from Duane Bada Vtec Club FTW Unorthodox Crank Pulley + some Decals. Also Exedy Stage 1 Clutch along w/ another Spoon Duracon shift **** & K-Tuned Adjustable shifter set up.
Novustech 10/15/20MM Spacers should be in sometime this week. Had them on my Wife's Lift'd CR-V before & they were outstanding.
Project Mu lug nuts & OEM Honda Single DIN Plate from Kristine & Tom from WA.
Body work & Paint Progress
Since we want'd to do a Spoon Sports theme, decided to do something a little Different. Here's is my Wife's odd Spoon Sports Collection but none of that New New items, all of them are Faded/Worn/Used/Abused to give her Civic some Character. Still have a bunch of New items which will be used for Functional/Mechanical Purposes.
Calipers
Gen2 Horn Button
Duracon Shift ****
Gen1 Oil Cap
Lanyard
Reservoir Covers
E/UKDM Emblems
Some more Updates & Parts Purchases. Modification List Edit as well.
Paint is done but still needs the J's Racing Spoiler, Rear Lower Garnish, "Spoon Sports" Driver Mirror, J's Racing/Chargespeed Lip etc installed. Civic is currently at my Buddies Garage get'n the New Heart installed along w/ some Suspension Components + Alignments again. Aim'n for end of June to be Drivable. Well on to the Pictures etc.
Spoon Sports Gen1 oil cap & bonus Logo Mark Decal from Jose Perez Luis
Mugen MF8's from Rudy Reza but just let them go over the weekend. Work'd a Deal out for the Defi USDM Amber/Red Gauges from Chris Timms, Oil Pressure/Temp Water Temp + Controller.
DTD Race Control Panel EF Civic from Dylan Towers Design, 1/3 in the US currently. Have some Plans in mind for a Configuration Cough Mugen Powa Cough ha
Spoon Sports Steering Wheel Boss (Hub) & Heat Barrier from Francisco Santiago & Johan Labrada. Spoon Sports Radiator Hose kit & Plug Wires in the background.
J's Racing Engine Damper w/ Spoon Sports Mount from Lorenzo. Go'n to Customize this item to Fit on her Chassis/Engine Application.
EC8 1.6i "ZC" Glass Headlights from Gerwin Kok. Using these w/ her VIS ZC Style Carbon hood. They came in from Netherlands w/ broken tabs & Seller wouldn't do anything to make the Situation right so we had to file a PayPal Dispute on him J's Racing hood & Custom Air Duct Headlight will be Track use only.
USDM Lower Console from Boso Daniel.
Weight Comparison, VIS Si-R Style Hood vs J's Racing Type-T Hood.
Beat up VIS Si-R Hood (Yes that's a Hole) vs J's Racing Hood weight comparison. VIS roughly 18 LB, J's Racing roughly 13 LB. About a 5 Lb difference, probably more since the J's Racing Hood is wrap'd up & the VIS is miss'n material.
Small little Collection for her Civic here in Texas wait'n while her Civic is actually 1,200 miles from us ha Seams to get Bigger & Bigger weekly
Few more Parts came in today EMS Japan.
Rigid Collar Kit, Type F Radiator Cap (Temporary), Heat Barrier & Single Lug Nut (Test Project) Rigid Collar Kit won't be install'd till late this winter. Rebuild'n her Full Suspension over winter & just Buy'n one thing at a time right now so it's not such a Huge Order when times comes.
Brotha Garber​ for Pick'n up her Autopower Industries​ 6Point Bolt in Roll Cage for us yesterday. Have some Plans in mind coming soon
Old Jun 4, 2015 | 05:31 AM
$amGD3's Avatar
Swaggylicious
Default Re: #teambrickner Wife's "Surprise" 90' Civic Si Track Vehicle Build
Old Jun 4, 2015 | 06:34 AM
StreetLethaleg6's Avatar
wow this is awesome!
Old Jun 4, 2015 | 07:22 AM
DC-2uned's Avatar
And to think this hatch would've been scrapped...thank God you/your friends saved it and turned it into a nice track-ready car. Alotta cool rare parts going into this and that 4x114 conversion is something you don't often see. Keep it up!
Old Jun 6, 2015 | 08:57 PM
Appreciate the Positive Vibes everyone. Well might not be able to Buy as much Gooodies as we Plan'd right now. We just acquired the "Tow Rig" for her Civic, 06' Odyssey Touring. Have about $1,000+ in Accessories/Maintenance we have to get done in a Month.
Transmission Oil Cooler
Power Steering Oil Cooler
Trailer Hitch Set up
Timing Belt & Water Pump
Navigation Update
Rear Adjustable Camber Arms + Alignment
+ lots more using all Motul Product.
Lucky we have a bunch of friends who still work for my old work (Honda) back home. Plan on Custom Fabricating an All Aluminum Single Axle Trailer Dove Tail, should be around 600LB or so.
Old Jun 7, 2015 | 02:58 AM
latino honda's Avatar
Nice build
Old Jun 16, 2015 | 04:39 AM
Buddy Scott put the USDM D16Z6 Engine & JDM LSD D15B Transmission in on Sunday. Spent the WHOLE weekend try'n to figure out the Post Mount issues. Hasport doesn't explain you can't use the Z6 Post Mount w/ their EFDHC Mounts. Went from using a Z6 Post Mount to A6 to B8 which was finally the Correct Mount but still didn't want to Line up Correctly. Scott had to take the Post Mount Studs out & use Bolts in order to have enough play movement to tighten the Driver Mount down. Rywire Harness should be here today, hope'n for Fire up late tonight. Only 6 Days till I will be driving her Civic on a 1,200 mile Adventure to Texas.
Old Jun 24, 2015 | 04:41 AM
HUGE Updates.
Civic is now Driving Made it's Adventure yesterday from Nebraska to West Texas 1,300 w/ ease. Spent Thursday through Saturday till 3 AM every night get'n her done when I was in town, well worth it. & now on to the Pictures.
Rywire Harness came in last week. (Tuesday 16Jun15)
UCA's install'd, Hardrace. PIC Suspension.
Engine Bay Complete for the most part. Install'd the Spoon Sports radiator cap when I got back home. Many more Spoon Sports Gooodies to be install'd this weekend tho
Some more Spoon Sports Action :p
Get'n there …
First time in months she's on the Ground.
Photo Shoot w/ my Mother's Flower Garden ha
Picture of my Odyssey & her Civic together for the first time but will be Separated for about a Month while all the Maintenance gets taken care of on the Odyssey back in Nebraska.
Fuel up before head'n over to Omar's to check out his MR ITR & his brother Leo's EG6 SiR in OKC
1,300 miles later made it to West Texas from Omaha Nebraska. Left at 2:30 PM & made it next Day at 11 AM. Civic did AMAZING get'n roughly 35 - 36 MPG if travel'n around 65 MPH. Only had one issue which was a Faulty TPS.
& her first test drive.
The Pure Excitement & Happiness Stephanie is feel'n right now, this is what it's all about. Positive Vibes 👍 now to get her some Seat Time soon 🚗💨
Old Jun 24, 2015 | 03:49 PM
ben_art's Avatar
SWINGS ACROSS THE STREET!!!!!!!
Old Jun 24, 2015 | 05:28 PM
DC-2uned's Avatar
Start em early!
Old Jun 28, 2015 | 08:11 PM
Wife install'd her Spoon Sports rear upper Brace & I applied her Spoon Sports heat barrier last week.
Size comparison Spoon Sports Twinblocks vs Factory R Calipers.
& install'd Had to remove the shield but other then that everything went Smooth.
Did a little Test Project i've had plan'd for awhile, 20MM Novustech Hub Centric Spacers + ARP Extend'd Studs w/ Spoon Sports Closed End Lug Nuts = Success
Test Fitment of the DTD Race Panel, try'n to figure out an configuration w/ the Mugen Push to Start Button/Switch & Defi Oil Pressure Gauge + whatever else we decide to Mount on the Panel.
Family effort #teambrickner taking apart the USDM Front End (VIS ZC hood) to install her J's Racing Type-T hood + Si-R items.
Old Jul 12, 2015 | 06:35 PM
Test Fitment on my Wife's Track Wheels today.
Desmond EVO's
15x7 +45 4x114.3
+20MM Front Spacers
+15MM Rear Spacers
Falken Azenis
205/50-15
These Tires will be her first Track event Tires, didn't want to get something to Aggressive as a Beginner.
Also another Lower Rear Lower Tie Bar, has some Wear & Oxidation etc. Came from a friend in Thailand. Let the Great Condition Bar go to our buddy Dominic for his Spoon Sports theme Integra Type R.
Old Jul 12, 2015 | 06:44 PM
Kidhuf's Avatar
Awesome ef hatch, I am really interested in your build in for updates. Good luck!
Old Jul 13, 2015 | 07:21 PM
Bently_Coop's Avatar
Steve at Heart
Solid build. Great job keeping it alive.
Old Aug 19, 2015 | 06:07 AM
Some more slow updates. Bought a few Spoon Sports Gooodies along w/ some Custom Parts + Fabrication by a buddy of mine.
Spoon Sports Gen1 Steering Wheel
Spoon Sports Speedometer w/ "Vtec Light" in a Si-R Cluster
Spoon Sports Rear Brace w/ era correct decal
Spoon Sports Ground Kit but was Scam'd on
AutoPower 6Point w/ Custom Bamboo Airbrush
EF9 Fenders Haf Cut w/ Custom lower stays.
Pretty much all I can think of right now, I know I'm miss'n a few things now on to the Pictures.
Since her Vehicle is Spoon Sports/Panda decided to get a little creative w/ a Bamboo Roll Cage
Here's the Progress on the Cut Fenders.
& the Spoon Sports items 😁
Old Aug 19, 2015 | 06:48 AM
American.Graffiti's Avatar
Love it!
Old Aug 19, 2015 | 10:56 AM
love this! those kids have the coolest parents and a double for the lil honda enthusiasts in the making haha
Old Aug 19, 2015 | 06:00 PM
toyomatt84's Avatar
Sanji
I love the airbrush work on the cage!
Old Aug 21, 2015 | 09:26 PM
Thank you for the Support Guys!!!
Prep'n for her first Track Day tomorrow. J's Racing Spoiler Mount'd, J's Racing Replica Lip Remount'd w/ J's Racing Screws & 3M Tape, Takata Harness ran & Alignment Check tomorrow AM at work. Really excited to see what she can do. Wife is very nervous but I'm sure she'll do Great.
Also her Spoon Sports EF Speedometer & Si-R Cluster came in a few Days ago. Also have some used Spoon Sports blue lug nuts in route as well, should be here next week.
Old Aug 23, 2015 | 07:41 PM
Finally, Wife was able to Race her first Event of the year. Better late then never & now she's Hook'd Already ask'n when the next Super Lap is.
& onto the Pictures, theres a lot of them.
Alignment Check before Event at my work.
Driving on to the Track for the first time. Friend Tim giving her the Go ahead.
Making her way around the Track, she mention'd be'n very very Nervous & go'n Slow basically not know'n what to do. Fellow Track Enthusiast let us borrow a Passenger Seat & I took her out w/ myself Driving. Stephanie said she felt Dizzy Light Head'd etc ha But now she knows to Push her Civic.
Stephanie try'n to hang w/ Tim but she was Gone like a Ghost L0L
Our Youngest Son Super Super Excited for all the Vehicles, all he was say'n was "Car Car Car"
Since we had a Share a Vehicle, her Best Times were not up. I ran a 1:27, this is my first time Racing as well.
EF Chassis's were the Dominate Honda Chassis for the Event. We all had to get some Pictures together
Matt, Jon, Stephanie & Alex. Alex took home first Place for Class A, Night Attack w/ a 1:26.
Old Aug 23, 2015 | 07:45 PM
Little Short Video of her Driving let'n that Rev Limiter know there is No Mercy ha
Old Aug 24, 2015 | 06:26 PM
Steve at Heart
<p>How did you get the hood J's Hood to fit with the USDM bumper?&nbsp;</p><p>Tracktime shots look cool. </p>
Old Aug 24, 2015 | 08:02 PM
Thank you, next Event is the 26thSept.
Has the Si-R Headlights, Corners & Filler Panel, that's all the J's Racing or Si-R Hood would need to Fit.
Old Aug 25, 2015 | 08:02 PM
Steve at Heart
<p>Cool thanks for the info. </p><p>Assuming you kept the stock T bar then.</p>
Old Aug 26, 2015 | 04:41 AM
indeed, Factory T-Bar.
